Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red status light
I have a fairly new bulb in a three year old 52327 TV. I get a fault coade of 4-4. What is that and how do I correct it?
  • Mitsubishi Master
  • 8,617 Answers
44 error means short detected. My experience with this chassis has bee Bad capacitors Jamiccon 1000uf and above. possibly the two 100ufs cap on the PWB have shorted. this chassis is no bad to worl on however without the service manual you will have a hard time even getting the chassis out to gain access to the boards to service. I recommend going to this link for 15.99 they will email you the factory service manual instantly and give some free tech support in case you need any tech support. Thats a nice TV and a repair shop will want to change boards and thats exspensive compared to a few dollars for new capacitors. But 90% of that chassis's problems can be traced to bad jamicon capacitors. Heres the link if you want the service manual
http://servicemanuals.vstore.ca/
Posted on Apr 18, 2008
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubushi tv model # 52327 ballast replacement
The ballast for the lamp too should be replaced along with the lamp. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Mitsubishi WD-62525 62" Rear Projection...
My Mtsubishi TV needs a new light engine...cost $799?
If one of your 4 fans stop working you will get a red blinking light. These do go bad after awhile. Part is under $10 at an electronics parts store if it is a fan. You have to open up the back and see if all 4 fans are working. If the light comes on after initial warmup then it is probably the main exhaust fan on the back cover of the tv. If it comes on during warmup period, then it could be your chassis fan. These are the two fans that usually will go bad.
Jun 19, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Wont turn on after bulb replacement
Make sure you seated the lamp right, but most likely the two 3300 and two 2200Ufd capacitors are bad on the power board. These routinely go bad after about 3-4 years of use on the tv. Parts are less than $10 bucks but you have to know how to solder circuit boards. Good luck
Apr 30, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light front of tv
If you still have a good picture, then NO, just reset your lamp timer. The instructions should be in your owners manual.
Feb 01, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
WD-52327 Red Light Problem
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Jun 05, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
