DVD drawer will not open in the hard drive of my computer. I know very little about computers. That is all I know is how to use one. Hope you can help
  • Swilin Sampson
    Swilin Sampson May 11, 2010
    hi,
    when you try to open the drawer, do you hear any whirring sound or any attempt by the DVD player to try to open?
    President:
  • 2,712 Answers
Hello ann_reid26
On the front panel of the DVD-RW, you should see a small hole, either above or below the tray. Take a paper clip and open it out. This should just about fit into the hole. Push the clip tip into the hole as far as it will go and keep poking around. This will actuate the manual release lever for the tray and the tray should pop out.
S-L-O-W-L-Y pull the tray out and take out your DVD. Restart the computer and the tray should go in automatically.
Hope this helps! You should be able to buy spares directly from the manufacturer or a local computer store. You could even try a google search to find a store near you, or you can purchase the parts online.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 23, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
No solution I could not reply to the question from one of your users. So still not working.
Posted on Apr 18, 2008
How do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
Cd rom drawer on dell laptop won't open
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
hope this helps, post back if you have issues.
Kind regards,
Amar Sondhi
Jan 22, 2010 | Dell Inspiron™ 600M PC Notebook
My cd draw is stuck in the cd drive. How do i get it open
you should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Sep 12, 2009 | Dell Inspiron 6400 Notebook
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Dvd drawer will not open
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using fixya.com
Jan 27, 2009 | Progressive Computer JSI 6 spkr. Home...
DVD/CD drawer does not open when button pushed - Averatec 3360
this is an issue with the tray release, built into portable disk drives. I would recommend replacement or repair by a good technician.
-this is not a software or firmware issue.
-this is an actual physical damage to the tray mechanism itself.
hope this helps you out.
Dec 22, 2008 | Averatec 3360-EH1 Notebook
Dvd drive
Open up the PC and check the power connector for your dvd drive, this may have come off.
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
