Question about Canon imageRUNNER 5570 Copier
Canon ir 5570 - error E000100-0001
Error E000100-0001 - reset error - problem remains
  • 2 more comments
  • Anonymous Apr 17, 2008
    I get an error message E000001-0010. Says to hit Shutdown key. Then says to turn off at the on/off switch at the upper right. Comes back with error message E000010-0010. Does anyone have a solution to this?
  • prntrfxr Apr 22, 2008
    i had this problem and error would not clear. turned out to be thermistor part of main cable was broken. difficult repair as I had no manual. cable also shorted dc controller out so I had to replace that.
    now I have a registration problem, but I dont have error code anymore.
  • prntrfxr Apr 27, 2008
    turns out registration clutch was bad and roller was worn. so i replaced the entire registration asm. works good now. sorry about lack of information. I've been a printer tech for 13 years, but only 1 year experience in copiers. I was working without a net since i had no manual. thanks for all your help. wished I'd had these sites when I was beginning in the industry.
  • Anonymous Mar 04, 2009
    Hello Spinal,
    Thank you very much for your script it helps me remove the Error code
    cheers,
    AZ
  • Canon Expert
  • 287 Answers
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
  • jeff heightchew
    jeff heightchew Apr 26, 2008
    Hello prntrfxr,
    Congrats on your progress! The only reason I get on the "FIXYA" site is to help folks. Not for ego and certainly not for monetary compensation since I receive none. I feel confident I can help you with your registration problem too. I did not realize that you had the previous expertise,talent and knowledge that you possess. At this point I will assume that you know how to go into service mode and have prior Canon experience. So please forgive me if the advice I give you now is no big help , but I hope it IS helpful. When you replaced the dc controller you of course altered the settings that were set unique to the marriage of the copier and its dc controller. If you open the front door and look on the inside panel of the front door near the hinge assy you will see the "front door label". It lists all of the settings that were used by Canon after the initial manufacturing of that particuliar copier (mass production) that were changed to optimize the specs of the copier. It even tells you which area of the service mode you need to be in.The settings include laser power, ccd offset settings,lead and trail edge blanking, and REGISTRATION to name a few. The values in the front door were valid when the copier was first born and reflect the unique characteristics regarding the copier and the previous dc controller and therefore may not be entirely precise considering the new dc controller. But.......its a starting point as far as re loading the values listed. And with that list of variables you have a guide if you need to fine tune anything. Good luck and I hope I have helped at least a lttle. Sincerely........SPINAL.......
  • Steve Jul 30, 2013
    Not sure if anyone is reading or posting in this forum any longer. I have recently experienced the same error code. Unfortunately it does not reset when powering down from the interface screen. When I restart, the error codes remains. It appears I cannot enter the service mode as it is "stuck" on the error screen.
You can help me about copy
Posted on Nov 25, 2013
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
Konica minalota 210 error code detials can everyone can give me the error code
If you are asking about a C0 210 code on a Minolta Di183 then this code means there has been a abnormal image transfer voltage error. The service manual says "the image transfer voltage remains more than 100V for a continuous given period of time while the PC drum remains stationary".
Have you opened/closed the front door or turned the machine off then back on to reset the code and see if it returns?
27 years working on Minolta copiers and I have never seen this code on this model of machine before so hopefully it will reset. If not you will need to call for service on the machine.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Konica Minolta DiALTA Di183F Copier
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Someone can help me?
u 162 means that the remaining ink is unknown. You have to hold the stop/reset button for 5 seconds or more and the error will be reset, but it won't tell you when the ink runs out.
Jul 14, 2009 | Canon MX300 Office All-In-One Printer
Maytag-Neptune stopped part way though cycle. Error code 0E shows on LCD panel. Powering down does not reset. I can't enter service mode as described in the washer manual the 0E code remains.
In general this error code is the main control.
Resetting by pulling out the plug may help, but I wouldn't count on it.
This would require a new main control board.
May 14, 2009 | Washing Machines
Problem in games & applications
unable to open games and applications folder.- error is showing = "operation failed " kindly help
May 07, 2008 | Sony Ericsson K550i Cellular Phone
Canon imageRUNNER 5570 Copier Logo
7,788 people viewed this question
old marine
old marine
