Question about Kitchen Ranges
KitchenAid Electric Range Model YKERI 201 - F3E0 Open Sensor Fault
    Genius:
  • 1,073 Answers
Replace the sensor
Posted on Apr 17, 2008
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
F3e0 error
may need more info.what sequince happens before this error occurs.does any other function operate correctly.
Oct 09, 2009 | Whirlpool SF367 Gas Kitchen Range
Error code f3e0, oven wont turn on, follow instructions to set temp, after hitting start, get 3 beeps.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Oct 03, 2009 | KitchenAid KGST307 Gas Kitchen Range
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
F3E0
F3 means the oven temp sensor has failed E0 means it failed open If you have a test meter i can tell you the resistance at room temp is 1100ohms. otherwise call for service Hope this helps PLEASE rate my solution Thnks...
Oct 02, 2007 | Whirlpool SF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
182 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
