Question about Epson EMP 720 Multimedia Projector
Panasonic PT L501U Projector
The Lamp is fine... I have 2 new ones used both... would the hour meter have anything to do with it? FYI the "LAMP" led is lit as well.... Any way to positively know its the ballast? Before spending all that money???
Also, I took to top cover off the projector, to see if there was anything i could see as an issue, there is a little led light by the fan that CANT BEE SEEN when the cover is on, that is red and is on... any thoughts???
Thanks again....
    Problem Solver:
  • 11 Answers
Is your projecot fixed? or are you still having problems?
Posted on Aug 06, 2008
  • 563 Answers
Ok , so the lamp is out then.
Before spending the money on a new Ballast.
Switch on the Projector while the top cover is off and check if all your fans are running.
The red light you see glowing on the Mainboard is quite normal.
Posted on Apr 17, 2008
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How to reset lamp hour of panasonic pt d6000se lamp
the lamp hour timer on the lamp housing, you can replace a new timer,
Apr 19, 2014 | Panasonic ET-LAM1 Projector Lamp for...
RESET THE LAMP HOURS OF PT-LB60EA
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Panasonic PT L501u Replacement Lamp
panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
thats all the unit powers off & when u check the lamp counter , its shows 0
u r done!!!!!!
Jan 22, 2009 | Panasonic PT L501U Multimedia Projector
Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Dec 24, 2008 | Office Equipment & Supplies
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Apr 17, 2008 | Office Equipment & Supplies
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Epson EMP 720 Multimedia Projector Logo
97 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
