Question about Maytag Washing Machines
I have a Maytag MAH5000BWW. When you press the start button the panel lights up but nothing happens. When you turn it off and press the start button again it is completely dead not even the lights. I unplug it and plug it back in again and the panel lights up again but the washer does turn on.
SOURCE: Control Panel
I have encountered the same problem and now I can use my washer again. Yay!!
Thank you.
Posted on Dec 02, 2007
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
Lumpy816
  • 246 Answers
SOURCE: Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Posted on Jun 16, 2008
  • 1028 Answers
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
find button with lock emblem beside it hold 3-5 secs
Posted on Oct 09, 2008
  • 7 Answers
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Posted on Dec 06, 2009
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Quiet Series 300 Will not work at all, only the lock feature is lit.
I had the same problem. The lock button light was on, nothing happened when pressing start, cancel, etc. I also tried holding the heated dry button (lock) for 3 seconds and no luck UNTIL holding down for three seconds while also pressing the cancel button. I was then able to start cycle as normal.
Apr 18, 2008 | Dishwashers
My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
Jan 21, 2008 | Maytag MDB9750AWS Built-in Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Apr 13, 2007 | Maytag 24 in. MDB5601AWS Stainless Steel...
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
