I cannot delete folders i put on a 1gb memory stick from my imac, i get error code 1407 or "you do not have sufficient privileges" messages
  • grl53 Apr 17, 2008
    i had the same problem with an old 120 mb stick and then realised it had a lock button which when unlocked allowed me to erase files, however the freed up space did not become available until i erased the stick with disk utility. i though i would do the same with my 1gb stick (no lock button) but when i connected it up i found i could delete folders normally - strange!!
    Problem Solver:
  • 5 Answers
This is something I have found... Read on
you probably will not like my solution but my problem was only a mini external drive with about 20 files. I opened each file and <save> to another drive. For me it was easy, I saved to my HD. Then open Disk Utility and <erase> my mini drive, which remformatted me a clean and usable drive. Then just copied the files I saved and DONE.
Posted on Apr 17, 2008
Error 1407 external drive
That's a Mac error stating that the file you are trying to delete is currently being accessed.
First, close all open programs and try to delete the file. If that doesn't work, eject the drive by clicking the eject button in a Finder window. Disconnect the drive. Reboot. Then reattach the drive and immediately delete the file.
Feb 17, 2014 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Tip
How to Delete Protected Folders from a Memory Sticks
<p>Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.<br /> <p> <br /> <p>1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.<br /> <p><br /> <p>2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.<br /> <p><br /> <p>3. Type the following commands in the command window:<br /> <p> <br /> <p>E:<br /> <p>cd "\ myfiles \ projects"<br /> <p>Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.<br /> <p>4. Type the following command to remove the attributes currently prevents you from deleting the folder:<br /> <p>attrib -r -h folderName /e<br /> <p>"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".<br /> <p><br /> <p>5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.<br />
on Jun 21, 2011 | Computers & Internet
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
The DCIM folder was deleted from my sony memory stick. How can I relaod this?
Assuming this is for a camera, put it back in the camera, using the camera's set up menu, re-format the card. (This deletes all data so make sure you've removed any photo's you want to keep before hand) Once completed, take a photo, the file system should be re-established.
Apr 06, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Error code #0x80070052 occured while attempting to transfer photos from memory stick back to camera chip
The error message means "The directory or file cannot be created."
Make sure the folder containing photos is having sufficient write permission .
Hope this helps .
Jan 27, 2010 | Fuji FinePix Z1 Digital Camera
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My Imation 1Gb does not work any more on my Imac 10.4.11 - it used to - i might have put it in a windows machine at one stage. Nothing I can understand comes up on disk utility when I click...
I just needed to tell you that your very small fee (no problems there) cost more than a new USB memory stick. But for my more expensive problems I'll be back. Thanks guys D
Jul 14, 2008 | Computers & Internet
Samsung D600 memory card format
When i insert memory card it says not allowed
Mar 03, 2008 | Samsung SGH-D600 Cellular Phone
Problem with the applications in the memory stick(1gb) SE K800i Unit
Remove the memory stick from mobile & put in memory card reader then connect to PC & try to scan the memory stick with latest anti virus,clean it & check the status.
Jan 09, 2008 | Sony Ericsson K800i Cellular Phone
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
