Question about Mitsubishi WS-65809 65" Rear Projection Television
Green and red outlines -- Help!
There are outlines around images and letters (display letters and such). If the set is turned off for a few hours, you can get a good two hours of television watching without it, but then it starts again. It's more on one side of the display than the other. I would automatically assume it was an over heating issue of some sort, however I don't know much if anything about electronics. Just seems like such an expensive item to ditch at the first sign of issues. Help?
  • Momma Rhonda Apr 17, 2008
    My husband is going to look at it this evening, he knew what IC and Heat Sink meant, so that is promising. I'll keep you posted.
  • 4,234 Answers
This is most likely due to a problem in sthe convergence circuit. Since it seems to get worse as the set is on, I would look first for poor connections around the convergence ICs. Bad connections can change the circuit characteristics enough to cause this symptom. Resolder the pins on these ICs. These are large blac ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Posted on Apr 17, 2008
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Seeing red outlines of letters/images and bent picture.
You need new convergence ICs replace both of them. they are located on the D board
Mar 23, 2008 | Sony KP-51WS510 51" Rear Projection...
Green Screen
If set displays intermittent green outlines around images, check DVI cable attached to DMD board from digital board. Poor connections on the DVI jack on the DMD board can cause the intermittent symptom. Pull up slightly on the body of the DVI cable connector and check video. Replace DMD board as necessary.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
