Question about Dishwashers
The top drawer of my dishwasher has just become extremely difficult to open or close, bottom drawer is fine. Can anyone suggest what the problem may be?
Sorry if this seems so simple, but try unplugging the dishwasher and plugging it back in. Ours had the same problem after our house cleaner ran it, it turned out that the cycle had been interrupted and the top-seal motor had not retracted the top-seal.
That worked for us, good luck w/yours.
Posted on Aug 10, 2008
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel Dish Drawer: I flooded it by using wrong soap. It was flashing F1 but I solved this by drying it out after removing the bottom drawer. That problem is solved but now the top drawer is...
Most likely the lid seal is dislodged and is obstructing the bottom drawer. Need to manually operate the lid seal actuator yoke and motor to bring the seal back to normal position. Can be messy.
Will need to get the bottom drawer out from housing and work on lid seal assembly located in the main housing.
http://spares.bigwarehouse.com.au/images/files/6145_5635c632f6805f5644d3f35b6feea5bc.pdf
Sep 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer: Does not start, just beeps once
Some sensors on the unit are telling the controller there is a fault.
Most likely the sensor checking the drawer is open or close is giving a fault. It is likely the drawer has come off the rail.
May 22, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
TOP DRAW VERY TIGHT TO OPEN AND CLOSE AND NO POWER TO TOP DRAW
The power filter board at the base of the dishwasher (under the bottom drawer) has a fault which shuts power to top drawer. The drawer is tight because lid seal actualtor motors are not operting due to lack of power, Try not to push too hard as the lid seal will be damaged.
Needs a technician to fix it unless you are good at handling dishwasher repairs. This is a very difficult one to handle for the non professional. The power board is about $100 to buy,
Nov 20, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Bottom unit does not always seal and causes water to collect in bottom pan which throw unit into f1 status. Sometimes it stays sealed and is difficult to pull drawer out. Is there a way to reset the unit...
These dishwashers are very sensitive to grime collecting around the drawer edges. Try cleaning with a damp cloth by rubbing along the top edges and the sides where the drawer door sits flush with the body.
Also trun off power at the mains and then turn back on after a short wait.
Oct 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Extremely difficult to open dishwasher door
if this is the solution other things should also be difficult, closing the door, sliding the baskets etc, - your dishwasher does not have a frame in that it is not rigid if the base is not level then your dishwasher will be twisted and things will not align, on the bottom of the machine is adjustable legs, similar to a fridge, a spirit level on the top not only front to back and side to side but diagonal as well and adjust the legs hopefully fixes your problem
Oct 03, 2009 | Dishwashers
I have a Fisher Paykel dishwasher Model # DD603. It is about 5 years old. My problem is that the top drawer is difficult to open Pulling it open it becomes easier once I get beyond a certain point. The...
Sounds like your lid actuators are not opening completely, they move the lid up and down. They are prone to failure, F/P has new actuators, German made, that can be installed and would probably solve the problem.
Jun 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drawers Stuck
the lid acuators have been up dated(due to this problem) though i find it hard to beleive both are bad
Jan 06, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishdrawer
It's look like something is obstructing the spray arm path. Follow manufacturer instructions on dishwasher's user guide pages 23,24 (how to clean all filters). In case you don't have the user guide,let me know by mail to dovdror@013.net and I will forward it to you. Good luck!
May 08, 2006 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
