Question about Marantz CD-17 CD Player
CD-17 will not recognize any disc on loading
Sudden failure of the 1999 CD-17. when any disc is loaded it is not recognized. After checking the loading process with cover removed I noticed the disc is not spun-up on loading. Any helpful comments / pointers will be much appreciated as this is a fantastic CD-Player that should be kept running.
Did this fixed the problem?, I'm having exactly the same issue with this player.
Posted on Nov 10, 2008
  • 4,234 Answers
The disc will not spin unless it is actually detected by the optics assembly. Try claning the lens using a cotton swab and alcohol. If that fails to resolve the problem, the optics have failed and should be replaced.
Dan
Posted on Apr 17, 2008
Can you tell us if this fixed the problem? I'm having exactly the same issue.
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 07, 2012 | Computers & Internet
Disk boot failure
Dec 04, 2012 | Foxconn G31MV-K Motherboard
Diskette drive 0 seek failure
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 25, 2012 | Dell Dimension 3000 PC Desktop
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media test...
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
I have thinkpad T61 it was loaded with vista. It
what kind of media are you loading? is this a DVD or a program disc? If this is a DVD disc, try loading a music CD or other type of disc to see if it is recognized. If so, its possible your PC DVD is unable to recognize that specifc type of DVD. Try other DVD's which you know worked before using Vista. Even though your machine says the device is working properly, check the Lenovo website for updated drivers for the DVD and the board chipset. Let me know if updating the drivers does not work. Meanwhile, I'll see if I can find out any more information from Lenovo.
Apr 08, 2010 | Lenovo ThinkPad T61 Notebook
Satellite A205 help "loading DVD"
Have you tried other discs? Does it read CD or recognize blank discs? Have you tried a bootable disc to see if it reads prior to Windows loading?
If the drive doesn't appear in My Computer this is a possible fix:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 19, 2008 | Toshiba Computers & Internet
3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Aug 01, 2007 | Yamaha CDC-565 5-Disc CD Changer
Marantz CD-17 CD Player Logo
519 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
