Question about BenQ MP610 Multimedia Projector
Benq MP610 does not project any picture
The projector worked for about 10 hours fter which the lamp refuses to come on. The new lamp procured also makes no difference but confirms that the lamp is ok but something wrong within the unit. The unit powers on but shuts down with blinking lights after a while. Please help
  • tandarin1 Apr 18, 2008
    The Benq MP610 initially comes on with its power supply LED being orange and the power on indicator button with light (just below the power supply LED) being green. All other LED's are off.
    When the power on button is pressed the orange power supply LED becomes green for a while and goes off. The projector starts with the fan noice but no picture/raster at all. This continues for the rest of the time with no LED's on except the power on indicator button light which is green throughout. The lamp is confirmed to be ok
  • Marnus Jacobs
    Marnus Jacobs May 11, 2010
    Hi there
    Which of the three LED lights flickers ? And what colour ?
  • 563 Answers
OK , then this is positively a Mainboard problem.
Check if this unit is still under warranty as the BenQ MP Series came out with a standard 3 year warranty and in which case will cover the replacement of this part.
Posted on Apr 21, 2008
I have not used my PB6100 for a little while and when I tried to run it I only had a plain screen. I could not even get the menu to show. The lamp had less than 300 hours at the previous showing.
George - I have a similar problem. Low light output, no blue screen, or BENQ power up - nothing but low light being projected. Did you solve your problem? Same as you we have not used the projector for a few months. TIA Jim
May 23, 2011 | BenQ MP610 Multimedia Projector
BenQ MP610 lamp focus problem - projection not clear
I just solved this problem. You have to remove the lense and adujst 3 screws. It may be delicate adjustment (about 0,5 to 1mm) but I solved the problem. Was not that easy to remove the lense, access is from the fron after removing the front panel. Cheers.
May 23, 2011 | BenQ Projector Lamp for MP610
How to master reset all
hi,
To reset the picture menu do the following.
1. Press the menu button.
2. select SETTING
3. Then select reset and press ok button (The following settings will still remain: Mirror, Language, Password, High Altitude Mode, Phase and H Position.)
if you need to reset the lamp hour do the following.
1. Press and hold the Exit ( up arrow ) button on the projector for 5 seconds to display the total used lamp time.
2. Press Auto on the projector or on the remote control to reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Mar 10, 2011 | BenQ MP610 Multimedia Projector
How to reset the time
keep pressing the enter button for 5 seconds while viewing the lamp usage.
Jul 16, 2009 | BenQ Projector Lamp for MP610
BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Sep 25, 2008 | BenQ MP610 Multimedia Projector
Benq mp610
I replaced my lamp on my Projector MP510 after the projector shut down. I followed the instructions in the book to reset the projector but the projector shuts down all the time. Please can you help me HARRY
Sep 14, 2008 | BenQ MP610 Multimedia Projector
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ MP610 Multimedia Projector Logo
295 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
