FixYa.com
Tags:
Hannspree Television
Code for sky remote control
posted by ejala on Apr 17, 2008
hannspree tv made in none taiwan what is the code for the sky remote if none is there a soultion.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 12, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I tried 0063 but at the end of programming sequence I pressed standby & TV did NOT go to standby so I repeatedly pressed TV then standby which in theory scans for suitable codes. Once TV went to standby I pressed select to store code. It worked for me.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 18, 2008
FixYa! (100)
ejala
Rating: 92%, 2 votes
tech guy from ebuyer said no code available but sky remote will work ok but volume and tele on- off facilities will not so use remote which came with television to do this so says he.
Can you Help with these Portable Televisions problems?
Hannspree (K206-10U1-005) Television
code for hannspree remote...
Blue Screen
I have a Hannspree LCD TV. When... Answer This...
Probleem turning power off
I have a 37 inch LCD GT03 and I... Answer This...
monitor settings
Monitor settings icon... Answer This...
Hanspree 37"
I have just purchased a... Answer This...
Repair Service
Find Portable TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
