HOW DO I RECEIVE PICTURE FROM MY LAPTOP TO THE PROJECT
I try to fix my projector to bring out picture on my laptop after all the necessary contection but is not showing any thing.
Pls what else can i do?
  • leighannw Nov 05, 2008
    I am having the same problem, but I don't see an f-key on my laptop with the two computers.
  • 563 Answers
Hi there
Right click on your desktop and go to properties , then go to settings and check if your resolution matches that of your Projector's i.e. - 800x600 for SVGA or 1024x768 for XGA
Also check in the advanced settings if your secondary screen is activated.
Then hold down the Fn ( Function button - located just left of you space bar at the bottom row of buttons ) and press in your F-row buttons the one with a screen or two screens - at the same time.
This pushes the siganl to the Projector if it doesn't pick it up automatically.
Posted on Apr 17, 2008
When linked to my laptop, the Sanyo PDG-DSU21N Projector will not project on the screen. It keeps searching for computer/ s video...etc. When I click on Menu, I do not have an option to select...
You need to send your laptop signal to your projector by pressing the FN key and the key that says CRT/or an icon of a screen (this is located at the top of your keyboard). 3l toggles will give you different images. i.e. projector image only, projector image and laptop image or just the laptop and not projector image.
Jun 02, 2010 | Sanyo PDG-DSU21N Projector
No picture
ok, first make sure projector is on pc, then on your laptop there will be a picture of a monitor on one of the top keys on the keyboard press that key whle at the same time holding the fn key these keys normally have a different color print on them
Apr 12, 2010 | Panasonic PT-AX200U Projector
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
I am trying to project a presentation from my toshiba laptop to a Hitachi data projector (new). The desktop and all have a red/pink tinge. i even tried just going into my pictures and doing a slide show -...
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
Oct 15, 2009 | Computers & Internet
Sim2 Seleco DLP SDV 100 Projector only giving white screen dimly.
it's a resolution issue. make sure the projector matches the laptop's resolution. the projector has a 800x600 native and a 1024x768 max. and it's not digital.
Mar 02, 2009 | SIM2 SDV100 projector lamp Projector Lamp
Aiming picture.
This unfortunately is the configuration of the lens. The projector normally does this to project the image upward for viewing.
The only way you are going to bring it down, is to jack up the rear of the projector, either with a book or something of that nature.
Good Luck
Glenn
Sep 23, 2008 | Sharp XR-10X Multimedia Projector
Bad connection between laptop and lcd projector
First, check all plugs and make sure there are no broken or bent pins in them. If the projector you are using have a replacable cable try to replace it to see if the cable is the problem. (borrow a cable from a friend or relative first so you don't buy one if it is not needed.)
If that doesn't fix it, try to connect a different computer to your projector to see if that is better. If so, the output port on your computer may be bad.
Also try to hook your compuber to a different monitor to see if that works. If no computers are able to make a good picture on your monitor, the monitor is at fault.
The fact that you can change the picture quality by wiggling the cable, and that it starts to search for a signal suggests that the cable or the plugs are at fault, but having the wrong resolution set up on your computer may also affect the image quality. Again, try to use a different computer as a source to eliminate (or confirm) your computer being the problem.
Feb 19, 2008 | Compaq Presario 2140US Notebook
327 people viewed this question
k24674
jasbo
jasbo
