Our TV screen no longer displays pictures, it just displays a blue screen and sound. The inbuilt DVD player still works with pictures and sound. Whay can I do to fix this?
  • ronald bryson Aug 15, 2008
    tv screen is solid blue but still have sound
    mitsubishi s-6041 60 in rear projection.
    we have tried another tv on same setup and it works fine
    so i dont think it has anything to do with satelite
  • 4,234 Answers
Without the make and model number, I can no tgive you specifics. In general there are switches that control the source of video and audio signals internal to the set. If the switching chip for the video section is defective, this can occur. Post the make and model and I'll try to provide more details.
Thanks,
Dan
Posted on Apr 17, 2008
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
May 25, 2014 | Coby TVDVD2050 20 in. TV/DVD Combo
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
    You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
    Aug 30, 2012 | Televison & Video
    Turn on tv have sound and picture then screen turns blue no picture but have sound
    Blue screens are a strong hint that your tv isn't picking up an image. Check to see if you have a firm connection on both your tv and your input device (cable box/ dvd player). You may want to disconnect and reconnect fully. Also attempt selecting other inputs. If you only have trouble with that one input, then you have a loose internal connection. Also make sure that your TV can display an image by trying to use the on screen controls.
    Sep 05, 2010 | Sony KP-53V75 53" Rear Projection...
    Toshiba 32a43 32' picture garbled mess
    If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
    Aug 03, 2009 | Toshiba 32A43 32" TV
    Compatibility with Samsung LCD Display
    It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
    Jan 13, 2009 | Marantz DV4001 DVD Player
    Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
    Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
    Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
    No picture but has sound
    Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
    Aug 14, 2006 | Zenith DVB312 DVD Player
    Televison & Video Logo
    Top Televison & Video Experts
