Question about Bosch Axxis WFL 2060 Front Load Washer
Can't Open the Washer Door---Our Clothes are held Hoatage
Ran a normal wash cycle----found water on the floor------Wiped the water up----did another wash cycle-----didn't overflow------but now cannot open the door to get our clothes out---Ran another cycle (and another cycle)---No leaks but the door will not open------I WANT MY CLOTHES BACK-----HELP!!!!!!!!!
Thanks
Naked Man in Distress..............
  • kagerber May 11, 2010
    Where exactly is the water level pressure sensor and the tubes that run to it?
Need to DRAIN it first. It wont open till you run the drain cycle after wash cycle.
Posted on Jun 19, 2008
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Posted on May 07, 2008
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Once the wash cycle begins, the washer door is locked and cannot open until complete cycle is done. Is this normal or is there a way to stop wash cycle and open the door?
If this is a front load washer, yes it's normal.
You wouldn't want your laundry and all the water falling out on the floor because the door didn't lock, would you ?
Jan 17, 2011 | Washing Machines
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag epic front loader
Suggestion: Check the wall inlet to see if water comes freely; then check if the inlet valves behind your machine to see they are not clogged. Best that u open the valve full before you begin your wash. The water coming 3 inches/door is normal. Dont try opening the door until after you hear a click or aft 2 or three minutes aft wash cycle completes.
Sep 11, 2007 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
295 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
