Question about Car Audio & Video
I have a broken rca lead and dont want to pull the whole lead out of my car to fix it, i am putting some new ends on it but dont know how to tell which colours are earth
    Novelist:
  • 100 Answers
Depends which kind of RCA's you have.....Most likly you have sheilded where there is a center wire and then strands of wire wrapped around the outside of the insulation of the inner wire. That outer wire is the "Ground" the inner wire would be you right and left signals. Good luck.
-Andrew Hawkins
Posted on Apr 17, 2008
Broken battery terminal on battery
New Battery
You know the problem ,the threads pulled out
of the battery,it's junk
Mar 10, 2014 | 1998 Chevrolet Tahoe
Need to know how to replace spark plugs and wires on a v6 mazda 2001
All you need is a deep socket that is the right size to fit your spark plugs and the new set of leads.
Spark plugs:
remove the spark plug end of the lead, use a screw driver and rag to place down the whole to mop up any oil that may be down there. remove your spark plug, place the new one in and replace the lead. simple as that really.
Leads:
These can be more difficult. As you pull the leads off the park plugs and distributor you will need to take note of which lead goes where and write it down. once all 6 are removed just simply reverse the process. A good rule of thumb is the length of the leadas to its location on the engine but dont take it for granted.
Oct 22, 2013 | 2001 Mazda MPV
The pull cord on my Craftsman gas blower model 358.794765 was jammed with about 6" sticking out. I took it apart and found nothing broken but now i cannot figure out how to put the spring in. There does...
Most likely the reason for the jamming of pull rope would be the rewind coil was over stressed due to use and age (they become brittle after a while) and where the coil catches on inside of housing snapped causing a slight unwinding and then the restricted movement of pull rope assembly. If you have it apart you should be able to see where the coil connects at both ends and attaches to its mating location. If you do not see the typical bent coil hook then your coil is broken. No worries, if this is the case, heat the broken end with a lighter or torch and use a pair of needle nose pliers and reshape to match the hooking location. Once completed, rewind coil and place masking tape around coil temporarily holding coil in place and leave yourself about three inch lead of coil to attach where it needs to go. Insert and fasten coil assembly then remove all pieces of tape. At this time your pull rope should be recoiling and rewinding pull rope. Always wear eye protection.
Sep 03, 2013 | Craftsman Garden
2000 cadallic backseat pull tab is broken, how do I fix it?
YOU HAVE TO CALL CADILLAC DEALERSHIP PARTS DEPARTMENT I DONT THINK YOU CAN JUST BUY THE SEAT PULL TAB IF BROKEN.THEY MIGHT TRY SALE THE WHOLE SEAT,
Oct 09, 2011 | 2000 Cadillac Escalade
Daewoo Lanos 2000 splutters and cuts out , heavy on petrol
Ive got the same car, here is two problems ive found that made it run rough 1. The ignition leads are a bad design and the metal clip that plugs into the end of the plug is very tight and quite often people just reef on the lead or rubber insulation on end of lead causing the lead to break off the end of metal clip on the end of it. Ive done it twice myself till i worked out that you need to grip onto the rubber insulation (the big rubber bit on end of lead) about half way along it with multi grips or something similar so you are actually pulling on the metal bit just above the plug and gently wriggle it off. My sister has same car too and all the leads were broken like this it was still running but like ****,new set of leads fixed it. 2. I had run my lanos very low on fuel a fair few times and it started to splutter and stall and was under powered for about a week so i changed the fuel filter ($15 AUS) and good as new. Hope this helps>
Jun 30, 2011 | 2000 Daewoo Lanos
Hi, one of the audio phono leads has packed up on my Technics 1210 after all these years. Have cut off the actual input jack (white) and was wondering how best to go about adding a new one. I thought this...
Hi, Replacing the rca plug at the end of the cable is just a matter of splicing the wires correctly. The wire is actually a 2 wire line, almost directly under the black outer casing will be the ground wire ( is actually going to be totally wrapped around the center wire ) this will be evident if you look at the cross section where you cut the cord. The replacement end can be purchased at the local Radio Shack, less than $3 probably for a pack of 2. When stripping the casing from the cord be carful not to cut away too much of ground wire sheath ( this may lead to difficulty in attaching new end ) it is almost inevitable to have a few strands of wire cut loose. The next step is to sort of " part " the outer sheathing, then kind of wrap both halves around the inner conductor as close to where you stripped outer sheathing away as possible. Next strip away the inner wires sheathing and you have the two ends to either solder, if you know how to, or tie through the holes of the replacement rca plugs leads. I hope this was of enough help and thank you for asking FixYa, Good luck-Prodzilla
Apr 16, 2011 | Technics SL-1210 Turntable
Gettin feed baq from the subwofer output still
#1 you need a ground loop isolator to put on the RCA cables. that should fix the problem... put one off the amp leading to the sub also cause that will also fix it these gorund loop isolators can be picked up at any electronic installer shop.., you might be able to find them at radio shack to but i would not buy those cause they dont work as well as the better ones, i would suggest any auto alarm radio installer shop.... hope this helps you...
Jun 20, 2009 | Dual XDVD8181 Car Video Player
My mp3 player not listed, i have (RCA 115a 5G mp3 player)
get a sledge hammer and bash it...put the mp3 plyer on the road and let it get run over...if that dont work ...well that sux cuz it because it cuz it cant be fixed now
May 19, 2009 | RCA Lyra RD2765 MP3 Player
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Looking for the air filter to replace it
look for a round plastic tubing leading from the motor. will be a large diameter. the end away from the motor should have a large black plastic box closed by either screws or clips.... remove those clips and you will find the filter.
Robert
Nov 12, 2008 | 2008 Volkswagen Rabbit
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
