Question about Sony Ericsson W850i Cellular Phone
HELP! HELP! HELP!
Yes, i can still received call and also play a music..i think it has a problem with the display error cause my phone still function as usually..hmmm..before this when i scan my memory card with bitdefender online, there are trojan virus effect..i have remove it and the problem still not solve maybe the virus effect my phone system..plz help me..(i also have reset my phone)
    Brigadier General:
  • 7,752 Answers
You need to reflash the firmware on the phone.
go to www.topsony.com this is a pay site
Posted on Aug 19, 2008
I Keep getting "playback error" "format not supported" on lgcf360
Hello All, I think I may have a solution for the 'Playback Error'problem with the LG CF360. Below, I have put the steps that caused my phone tohave the error and then the steps I took to get rid of the error. Firstly, my CF 360 worked well for hours of playing songswithout any error. Then, after I did the following steps, the error happenedover and over.
  • I pushed a mp3 ring tone via blue tooth to the phone with the SD card in. It saved the ring tone in the SD card, but I wanted it on the phone in case the card was out, it would still ring.
  • I took out the SD card and pushed the same file to the phone, so it would save on the phone and not the SD card.
  • I also pushed another mp3 to the phone.
Then, the "Playback error" happened intermittently every fewminutes. This may have been caused by either
  1. The phone's library of mp3's being corrupted because of the same file in two locations, or
  2. The phone's physical memory getting too low to effectively play music.
Here are the steps I took that got rid of the error.
  • Delete the duplicate mp3 from the SD card
  • Move all music mp3's to the SD card and off of the phone.
  • Move some pictures to the SD and off of the phone.
  • Shut off phone
  • Take out SD card.
  • Turn on phone and try to play a playlist of songs that were on the SD card (causes the phone not find the file and update the music library)
  • Put in SD card while the phone is on. (causes the phone to re-build the music library).
After I did this, I have played mp3's for hours without anyerrors at all, just like before. Either I had too much stuff on the phone orthe music library was not correct causing the crash. I hope it helps. Mike
Aug 14, 2009 | LG CF360 Cell Phone
Panasonic kx-t7730 plays music when phone receiver is on phone
HANG UP THE PHONE AND PRESS 1 THIS WILL STOP THE BACK GROUND MUSIC.
Dec 13, 2008 | Panasonic KX-T7730 Corded Phone
N70 White display
its about display connector.follow display wires & try to fix the connectors
Nov 03, 2008 | Nokia N70 Cellular Phone
Error
Can you play at least one music from your mp3 player? If yes, the file that you're trying to play when this message appears may be corrupted. Try having another copy of the music that you want to play on your mp3 player. If you can't play any music that you transferred, possible causes could be :
1. Your mp3 player was reformatted to another file system that is unrecognized by the mp3 player.
2. The flash memory of your mp3 player was bad
3. The songs that you're trying to transfer is not known by the player ( file types other than .mp3)
Aug 17, 2008 | GPX MW3837 MP3 Player
Alpine 9813
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
Jul 19, 2008 | Alpine CDA-9813 CD Player
HELP!
ok...so i cant fix your fone here.. the problem is a hardware failure, there's 2 possibilties, either you have to replace your lcd, or replace the flex ( its the connector between your board and lcd )... tahst's the 2 problem u've got, or it maybe a loose connection that only may fix by cleaning it or re attach the connector on both sides of the flex.. less charge .. gotta go to your nearest service center to fix that.....
Apr 17, 2008 | Sony Ericsson W850i Cellular Phone
CAN'T GET MY MUSIC PLAYER TO PLAY VIA MY SBH-170 BLUETOOTH HEADSET
I think the samsung T629 does not have stereo bluetooth. It would have to have a 2.0 class bluetooth profile to play music through the headset
Jan 19, 2008 | Samsung SGH-t629 Cellular Phone
Error message M506
I also had this problem and thought my music players were broken. The media players displayed the songs as 00:00:00 even when the file info read that it took up space and had a song length. The music player displayed that m506 error message.
I looked through forms for an answer, and I noticed I didn't try messing with one thing: THE BATTERY.
Try taking the battery out of your phone and putting it back in. It worked for me! My music players work again!
Nov 04, 2007 | Samsung MM-A920 Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
