Machine stops mid cycle and does not drain. machine is whirlpool AWM6100/S
  • mollyandmind Apr 25, 2008
    my whirlpool - lsr8233ez1 is doing the same thing. I checked the lid switch and found that it's broken. I nfixed it myself thanks to the instructions found here and now everything works GREAT!!! Thank you so very much!!!!
  • 5,911 Answers
If your symptoms are:
1. Washer fills
2. Washer agitates.
3. When washer gets to spin cycle, it stops.
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and can usually be found at either repairclinic.com, or searspartsdirect.com. Just type in your COMPLETE model number (located around the lid opening) in the Search menu.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Apr 17, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 18, 2008
    The last sentence I added was asking you to let me know if
    you needed further assistance. It would have been considerate of you to
    leave some feedback rather that rating this as "Inappropriate" with absolutely
    no comments. Were you able to fix this problem? Does your washer
    still have a problem? Do you need to troubleshoot the symptoms
    further? I am familiar with the washer
    functions and symptoms of some of the more common problems because I have
    worked on it numerous times. The solution I provided was the best
    assessment I could give you based on the one line sentence you provided as a
    question. The technicians on this
    website provide their assistance at no charge.
    There’s quite a number of years experience represented here, and many of us
    take our valuable time to carefully read through each consumer concern to try give
    you the know-how on how to fix things yourself.
    Most importantly, this saves you money!
    Appliance repair services are not cheap. Many of us are current or former appliance
    repair technicians. The least the
    consumer could do is use these forums correctly by “discussing” your problems so
    we can diagnose them more accurately.
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Mar 09, 2010 | Whirlpool AWM6100 Front Load Washer
My Whirlpool washing machine AWM6100 is weird. it washes no problems but when it comes time to drain there is an awful noise any idea? it does drain and spin its just the noise
you may have something stuck in the drain pump that is rubbing or grinding on the impellar wheel
check for any obstruction in the drain pump and the hoses that led in and out of the drain pump.if you do not find anything then you may need to replace the drain pump. as long as this noise only happens in the drain cycle.
Feb 09, 2010 | Whirlpool AWM6100 Front Load Washer
Reset whirlpool front loader
Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
Mar 21, 2009 | Whirlpool Washing Machines
Whirlpool AWM 6100/s - stopping mid cycle, not draining - unusual whirring noises, programme stops with '0' and '100' flashing on spin meter as well as paus and 'wash'
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Jan 26, 2009 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    190 people viewed this question
    Top Washing Machines Experts
