Printers
Problem for Printers
Generic problem for all Printers
Printer not working Error offline
By bcoleman738 on Apr 17, 2008
Same Problem
Apr 19, 2009
-   my lexmark X83 has the offline problem. when I go to properties-port-configure I do not seem to have the choices you solvers mention. -   aaabbbme
Jan 20, 2009
-   I have been stuck in offline OR busy mode for two days now. I have tried reinstalling, downloading drivers and - as said by another - to no avail!-   Guest
Jan 13, 2009
-   Printer offline, have changed option to print online to no avail!! Have switched printer off and on again, rebooted computer etc, still not working?? Please help urgently-   kathleen928
Jan 12, 2009
-   printer offline always, option on line is marked, getting really pissed-   vdmraf
Sep 10, 2008
-   LA 650 tally genicom printer has an error offline when printing-   dsdaviau64
Solution #1
posted on Apr 17, 2008
Somewhat Helpful)
Basti
Rank: Wiz
Rating: 85%, 822 votes
Go to prnter and faxes under control panel, look or your printer icon then right click on it, on the dropdown menu select use pritner online and left click on it, make sure printer is connected and turn on, right click back and cancel all documents. then try printng when status says ready and 0 documents pending.
pls dont 4get to rate as Fixya if problem is resolve.
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #2
posted on Mar 03, 2009
Helpful)
jhanj
Rank: Apprentice
Rating: 93%, 37 votes
I recently resolved the same problem by going into the Printer and Faxes under Control Panel. Look for the printer icon that shows in offline status. Right click 'Properties' and go to the Ports tab folder. Select the Port IP address in question and click on 'Configure Port' button. Click on the check box next to SNMP [SNMP status enabled] to remove the check mark and to disable the option. Click OK on the Configure Port window. Click Close on the properties window. Hope this helps.
Was this helpful?
Yes
No
26 people thought this was helpful
Solution #3
posted on Jan 03, 2009
Somewhat Helpful)
MemphisPCGuy
Rank: Apprentice
Rating: 86%, 11 votes
1) Select the Properties of the Printer. (In Vista Right Click Printer > Run As Administrator > Properties)
2) Select the PORTS tab
3) Select the Printer Port (BRN00807710654E or something similar) and select CONFIGURE
4) Change the Printer Name or IP Address to the actual printer IP#
Please Note: This will work better if you set your printer to use a static IP#. Simply select a ip# above the DHCP range of your router. This will stop the printer from ever receiving a different ip# at start up.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Feb 24, 2009
Somewhat Helpful)
Grama gg
Rank: Apprentice
Rating: 79%, 6 votes
I have two printer HP and Epson, the Epson says offline. I have three computers on the same network. Don't know how to change from offline to online. I'm on Vista, both of the other computers are on XP.
Thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Aug 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I tried this says operation cannot be completed. Any other suggestions?
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
looking for an all in one printer, have a cannon pixma mp 500, darn thing started spewing black ink... (More)
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
I have HP LJ3055 printer, when i want to fax it then it shows Memory is low, I alreary clear the... (More)
Answer
i can print on my tally genicom 5040 but the left side of the print is cut or cant be printed
6 Other Users Have The Same Problem - Continued
Comment by kenly777, posted on Jul 15, 2008
I have tried the previous solution to no avail. It already says that it is online (rather than offline). I have checked everything and am extremely frustrated.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
