Boot problems HI I tryed to install xp alongside vista but something went wrong, now i can't boot my pc. It stops at the POST screen and doesn't load any OS,also i can't get in the BIOS either.Please help if anyone has any idea of what has happened. Thank you
  • elektroboyit Apr 18, 2008
    Hi Stef, I think it might be my HDD not working.I have tryed to disconnect it and turn on the pc,it loaded the POST screen and gave me an option to reset the BIOS wich i did,after that it carryed on booting from the cd but stops becouse the HDD is not connected (I think).I have then tryed again with the HDD connected and it stops after detecting the HDD in the POST screen like before. So is it the HDD that is faulty?! And if i get a new one will it be possible to do something with this faulty one? Like reformatting it?
    thank you for your help
  • elektroboyit Apr 19, 2008
    thank you Stef,
    this HDD is definatly not making any sound or "reading data noise" = fryed ;)! I will shortly get a new HDD.
    I will let you know how things goes!
    kind regards,
    Alex
    Scholar:
  • 55 Answers
OK if you can't get into the bios, did you try to reset the bios ,or CLEAR the CMOS ? If you can't get into the BIOS then either your MB/HDD is faulty or your BIOS is just stuffed and needs to be cleared. Let me know...
Kind Regards
Stef
Posted on Apr 17, 2008
  • Stefan Groevens Apr 18, 2008
    OK... if your HDD does not pass the BIOS screen if connected AND if your PC boots up until "no hdd connected" or as you mentioned "Cd does not continue because no HDD installed" then your HDD is faulty indeed.
    The problem is now : How would you access your drive when you get a new HDD ? The issue is here I suspect the board from the HDD to be faulty. A faulty board might cause "malfunction" or a "mislead data transfer" from your HDD board (faulty) to your BIOS. Thats why you can not pass the BIOS, cause the BIOS has trouble communicating with the faulty HDD board.
    If you would have a new HDD, and your would try to connect your old one, with the new one already connected, I assume that it will also not pass BIOS.
    Down here we would have an old board lying around somewhere in the workshop and just swap the faulty one with the new "old" one, which would work to "retrieve" the data and transfer the data to a NEW HDD. And because data recovery is EXPENSIVE, options would run out here.
    What you can do to make 100% sure that your HDD is DOWN, try installing a other HDD (one you can get from a friend for testing - that you can use to install an OS ). OR you can leave your case open and "listen" to the sound that the HDD is making: If you hear NOTHING coming from the drive, then your HDD is most likely to be dead, if you hear "cluck cluck" noises then you know your HDD is faulty, if you hear a spin up spin down all the time, you know the HDD is faulty, If you hear a steady spinning with "data reading sound (how should i explain it - well it sounds "healthy :-) ) you know that your HDD is fine but the HDD board is fried or faulty.
    Let me know...
    Kind Regards,
    Stef
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
Blue Screen Error Windows 7 Dual boot config: stop: 0x0000007e (0xFFFFFFFFC0000005, 0XFFFFF80002EE4338, 0xfffff8802fc4838, 0xfffff88002fc4OAD) I have a Hp pavilion dv-7 1020us laptop, getting a blue screen...
If have Bootable windows 7 install it .
Installation guide WIN XP http://www.windowsreinstall.com/articles/bios/ http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx VISTA http://vistaultimate.windowsreinstall.com/repairstartup/repairstartup.htmHope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Computers & Internet
How to dual boot xp and vista?
First of all partition a drive up. Make sure its a large capacity drive, something well over 100GB.
Boot the computer with CD/DVD set as the first boot device and pop the XPmag-glass_10x10.gif CD in the drive and allow setup to begin. When you come to the screen where you select the drive partition you should see the drive listed with all the space listed as unpartitioned. If the drive was in use previously, you'll need to delete all the existing partitions. To do this you'll have to hit the 'D' key followed by the 'L' key. The screen instructions will be visible to guide the process.
Once all the existing partitions are deleted the display will show the total unpartitioned disk space.
Hit the 'C' key to create a partition. Personally i partion mine to 80GB (81920MB)
On the newly created partition, (not the raw one) install XP on that. Carry on with the installation until its final restart, it will be a light blue screen.
Quickly pop the Vista disk into the drive and start the Vista install. When it askes where you want Vista choose the unallocated partition. If you let XP load up first then you will not have the dual boot option on start up.
If you have done this correctly then each time the computer restarts during Vista install you see a boot message on screen saying "older version of window(XP) and Vista.
Lets Vista fully install right up until it loads the welcome screen. Then you can restart the computer, choose older version of windows to complete and load the XP operating system.
You then have to switch between them both to install drivers, software etc.
If you want to use both operating systems at a time then you need a virtual operating system installed but they are not that good as memory is kept at a minimum.
Good luck and please post back if you need anymore advice.
Regards.
Jul 15, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I was using windows vista on Toshiba Laptop. I got a problem on it then I try to format C: then try to install Windows XP but got a problem. When try to install XP I can get message like Stop:...
Please note before I continue on that XP can not always be placed onto a system that had Vista as some drivers and hardware will refuse to work.
You may be having an issue w/ the boot manager.
I would suggest running the windows xp recovery console this will give you a dos like screen. Once there you can do a lot w/ the system I would suggest trying to rebuild the bootmanager.
If none of this works. You should try a full not a quick format off the install screens or you can run a win98 boot disk and access the partition and format commands.
Please post your findings in as great of detail as possible.
I believe at this time the bootmanager may be confused as to if its dealing w/ visita or if its dealing w/ xp. The boot manager uses a part of the harddrive outside of normal storage to control parts of the OS loading procedures.
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Toshiba Satellite L515S4960 Notebook
While installing windows xp monitor went blank, cd started to blink and would not open. I was useing a crt monitor at the time due to the fact thats alli had. HELP, what's wrong
Turn off the computer. Try unseating and reseating the memory one stick at a time in each slot one at a time. After each reseat of the memory try turning on the computer and see if you get video back on the screen.
If not then try another monitor. If all that doesn't get video back on the screen then the motherboard is bad in the computer.
Nov 26, 2009 | Dell Computers & Internet
I can't load win xp
check the hard disk option in bios or load bios setup default then check
Aug 25, 2009 | Asrock P4I45GV R5 Motherboard
My second HDrive went faulty as VISTA does not like XP
try to use hiren's boot disk or something similar (OS bootable from CD)
Aug 06, 2009 | Acer Computers & Internet
Toshiba satellite A205-S5804 VIsta to XP
I had the same problem to make dual boot on a vista loaded laptop with XP. I use nlight to splitstream the RAD and it was successfull.
  • Try this link, there is a very nice article regarding this problem with pictures.
  • You can also try bootdisk to make a bootable CD then start with this CD and try to run your setup. Click here for bootdisk
Please post your feedback.
Thanks
Iqbal
Jun 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Want to downgrade from windows Vista to Windows XP
Hi ginger,
Suggest you back up you're personal data to either a CD/DVD or mem stick.
Windows in general will not allow you to downgrade. It does not matter what version you have. If you put your windows CD in your CD-ROM & boot the Win XP CD you will have to format the hard drive. Only than will windows XP install. Everything on your PC will be erased. If you’re sure this is what you want than put your Win XP CD into your CD-ROM & restart your PC. You should see; to boot to the CD press any key...... (Press the space bar). Win XP should start to load. If windows does not start to load, restart your PC & press the F8 key every two seconds. This should bring up a boot menu, use your up & down arrow keys & highlight the CD-ROM drive than press enter. Windows will begin to install. Choose format when shown on your screen. If you choose to re-install windows you will end up with double folders & that is no fun.
Good Luck!
If I can be of more service, just post back & let me know how thing went.
Mike
Apr 24, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
