Question about Nokia N95 Cellular Phone
Keypad # 9
Need help! i'm using a nokia n95 8gb (finland). every time i press the # "9" my phone restarts authomatically. whichever application im using.
  • 85 Answers
It is a software problem .go to repair center for flash ur mobiles software on ufs
Posted on Apr 17, 2008
My Nokia C3-01 keeps freezing, can't log in to get
This solution should help fix the issue. I advise you use the Nokia PC Suite to backup your phone data prior to doing this reset. Also, you should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
  1. Enter *#7370# code from the keypad. and press the Dial button.
  2. Type unlock code 12345 press continue.
  3. Restart your phone.
  4. You should check for updates on the phone at this time Enter *#0000# from the keypad and press the dial button
  5. Select "Options" and then select "Check for updates".
Remember to backup your phone before performing these functions.
May 15, 2011 | Nokia Cell Phones
Tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Press*#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 | Cell Phones
I am having problems with my nokia e63 keypad that seems not to unlock. at times the whole keypad dont respond when pressed Hudson, Kenya
you may have loaded your phone with a lot of applications. you may also have to try to delete some unwanted stuff in the same. it helps a lot. if you feel you can not delete then move them to the memory card.
Apr 09, 2011 | Nokia E63 Cell Phone
I want to refresh my nokia,. I want to format all,,,other information except nokia software,...... Please help
Press *#7370# from keypads of your Nokia E63 then your phone will ask ''Restore all original phone settings?Phone will restart'' then press yes and it will delete all the applications,games,music files,contacts,messeges etc from your phone and phone will become fresh like you have purchased a new phone from the market and software will set to factory settings and then you can re arrange all settings as you like.
To know about your phone software and model No. press *#0000# any time (before formatting the phone and after the formatting the phone)it will be the same untill you update a new version of the software.-Mehboob Allana
Dec 07, 2010 | Nokia E63 Cell Phone
Whenever i open my nokia N93 it comes up in landscape form, the camera authomatically switch on and the keypad does not function
i think the camera switch is broken just replace it with the new switch,it also the same with nokia 6260
Jun 03, 2010 | Nokia N93 Cellular Phone
Music application is not working properly.. i cant go to the next song when im playing it...
You need to restore factory settings .
Here is the way :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck
rate if useful please !
Feb 04, 2010 | Nokia E75 Cell Phone
English version of Nokia 5730
actually all the langage of the phone i sum coutries is set to local language.. for example when n 97 is lanched in china thn it works in chineseand its keypad is also in chinese.. in germany it has a zwerty keypad instead of qwerty keypad according to german language..
so language means the languge of the phones Operating sytem nd the keypad
Sep 06, 2009 | Cell Phones
Nokia 6510 keypad problem
i think u have to clean ur phon.. open it & just wipe it.. im sure it will work
Jun 01, 2009 | Nokia 6510 Cellular Phone
Nokia 3230
Personally I use this phone.
You need to format the phone. To do that press *#7370#
Phone will ask for security code, press 12345 (if you've not changed the sucurity code) , then ok
Phone will restart and will take some time to format. After format you'll find your phone speedy.
Don't forget to back up all your phonebook and other necessary files before format.
Best of luck
May 24, 2008 | Nokia 3230 Cellular Phone
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Nokia N95 Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
