Question about Geovision GV-650 BNC (GV6504) Video Capture
Key Pro not found
When i restart my computer after install, it give me this error: "Key Pro not found". the error comes from Surveillence System GeoVision
  • thomasa_nm Jan 14, 2009
    I have Geovision GV-600, When I do restart i get this error "Pro Key Is Not Found".
    Please any body can help me
First you turn off your computer and remove PCI card for 30 second and put it back, and turn on computer and then it wook
Good luck
Posted on Jan 15, 2009
Can't read data from registry in geovision
try reinstalling the software again and full install it and then restart your PC and if it shows the same message then be sure that it is not the genuine software. OK
Apr 07, 2012 | Geovision GV-800-16 Video Capture
Gv800 software v8.3 after install into win 7 32bit pro with no problem,but when i login can not see anything , only the black image, why ??
You could try this in either order
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps you
Aug 17, 2011 | Geovision GV-800-16 Video Capture
My geovision multicam program(gv-800) will not respong I have recovered my computer and it still wont respond. Please help!
Having recovered means there was a problem before. try to install the device drivers for the video capture card all over again
Jul 15, 2010 | Geovision GV-800-16 Video Capture
Geting error cant find pro key
try uninstalling software and re-installing also it could be a compatibility issue with the motherboard. SIS, and VIA chipsets are not supported by GeoVision.
I have found that ASUS mainboards work very well with Geovision.
Aug 11, 2009 | Geovision GV-650 BNC (GV6504) Video...
I have a pc running geovision 250 and was wandering where to look for the video recordings
The recording are saved in c:\gv250 if you have just C driver and then you browse to folder for specific recording. If you have multiple hard drive you can check from Geovision Main system software setting to figure out here the recording are stored. Easy way to do that is stop all monitoring in main systems and then press F9 for systems configuration and go to storage settting. There you will see path for saved recording.
You can also view your previous recording right from GV main screen by just pressing F10 key and then select the date and time you wanna watch recording for.
Thanks
Apr 13, 2009 | Geovision GC-250-2 (gv-250-2) Video...
Can't find USB key.. GV 800 v7.05
Install Version 6.05 that should do it
Jan 12, 2009 | Geovision GV-800-16 Video Capture
PC w/Geovision 650 (800S) Card reboots but safe mode fine
Sound like a bad PV800 Card send to GeoVision to Fix
Nov 21, 2008 | Geovision GV-800-16 Video Capture
Geovision 650 not playing in my computer
You require Geo codec's. that is software to play that rare type of video format on your computer. just Google geoivion codecs or load them from your geovision software disk.
Aug 25, 2008 | Geovision GV-650 BNC (GV6504) Video...
Gv-600
u may hve been supplyed with the worng disk u need to go to a website called ezcctv and sign up dont worry its free there u can download the version software for the card. make sure to check if the drivers have installed u can do this by right clicking my computer go to properties check all drivers have been insalled
Nov 27, 2007 | Geovision GV-800-16 Video Capture
Geovision install
Please make sure that your motherboard does not have a VIA chipset. Can you post the exact specs of your machine. Also how old is the card, and what version of software are you installing (it says the version on the CD)?
Oct 22, 2006 | Geovision GV-800-16 Video Capture
Geovision GV-650 BNC (GV6504) Video Capture Logo
1,843 people viewed this question
Top Geovision Televison & Video Experts
Brian Sullivan
Brian Sullivan
Q4SteveB
Mark Taylor
Mark Taylor
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
