Laptop function keys are nt working
NC 6910P hp compaq laptop's function keys are nt working
  • 1 more comment
  • Anonymous Jan 16, 2009
    my button to transfer image on lcd not work
  • Anonymous Apr 08, 2009
    my laptop functions keys won't work. for example "Fn-F6" i am rly mad becuz this wont work. plz help me!!!!!
  • Anonymous Mar 13, 2014
    HP Compaq 6910P power supply schemat
    Scholar:
  • 55 Answers
2 possible solutions...
Reset the BIOS: Works in most cases
Reseat the keyboard: Sometimes it is possible, that the keyboard connector comes loose and thereby causing a malfunction with some keys or overall fails to work.
Posted on Apr 17, 2008
Hi Dear
The first solution is a good one....Thanx for your valuable advice!
Regards
Divu
Posted on Apr 21, 2008
Hi dear
purchase a new keybord
Posted on Nov 16, 2008
How do I enable the webcam and turn on wireless capability on HP compaq 6910p
above the function keys (F3,F4 or F5) you will see the wifi icon touch that icon and should light up. indicating wifi is on.
thanks
Apr 01, 2014 | HP Compaq 6910p Notebook PC PC Notebook
Firewire 800
I don't know, but regardless, if you have a firewire connector on your laptop, it will work. If old like mine, even if the camcorder is firewire 800 ready, made for 800, it will run at 400 (just like my laptop can do USB 2 but cannot do usb 3... so it sends at USB 2 speeds.) The firewire connectors look the same for both 400 and 800 btw. <:0} So it doesn't really matter.
May 29, 2013 | HP Compaq 6910p Notebook
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Where dos jumper located on compaq 6910p and how can i remove bios password on 6910p
Most "laptop" computer do *NOT* have a jumper that can be used to bypass a BIOS password.
This is DELIBERATELY done, so that a thief in possession of your laptop cannot bypass your password, and thus cannot use your stolen laptop.
Find your original bill-of-sale, to prove ownership, and telephone HP/Compaq, and ask for Technical Supoprt in resetting the BIOS password.
Jun 20, 2011 | SIB SATA 250GB for HP/Compaq 6910P NW8440...
Like to the dail up connection but my moden does`nt take it. my moden is a hp nc 6220
Check your internet settings connection, to dial up your connection to modem, if not function check it if wat is compatible to your pc notebook.
Jun 03, 2011 | HP Compaq nc6220 Notebook
Built in mic for my laptop hp compaq 6910p is not workin
Jan 19, 2011 | Computers & Internet
Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
Apr 24, 2010 | HP Pavilion dv6000z Notebook
Not getting sound
check your sound drivers,and the sound mixer
Apr 02, 2010 | HP Compaq 6910p Notebook PC PC Notebook
Hp2530 error xxx STOP: 0x05001411 (0x00000000) (0x00000000) (0x00000000) (0x00000000)
Please see solution to
Generic problem for all HP Laptop Accessories Hp2530 error xxx STOP: 0x05001411
Changes and Corrections in 6.3.1 HFA3
The following items were corrected in Pointsec PC 6.3.1 HFA3:
ID
About
Details
453083
HP Compaq 6910p blue screened intermittently in preboot.
An unrecoverable error occurred intermittently in preboot on HP Compaq 6910p Notebook laptops.
http://dl3.checkpoint.com/paid/26/Pointsec_PC_6.3.1_HFA6_Revision_Tracking.pdf?HashKey=1264440272_c655ada20b1069217b99da7fb5d572d5&xtn=.pdf
Jan 25, 2010 | HP Computers & Internet
How to replace the Keyboard?
if you are not sound on technical ground its better to be done by the technician
Oct 17, 2008 | HP Compaq 6910p Notebook
Computers & Internet Logo
1,269 people viewed this question
David Payne
David Payne
