Question about Lands Phones
We have 2 handsets (phone) bought as a pair using base station cd135 all was ok last night but today when woke up we cannot make calls from either unit, the units are showing searching on both handsets and have tried the general troubleshooting in the hand book. i am a qualified electrician and have put the cause down to be a faulty transformer/power supply unit ours being model no sa35-28bs-1 input 230v output 7.5v dc @300ma 2.25volt ampere can you reinforce my theory that this transformer is to be suspect. as if it is we only got these at christmas.kindest regards andy
If you didnt charge people for assistance i would gladly tell you how i fixed it .why should i give you the solution so you can charge people, by getting the information for free then charge people for the priviledge sorry not going to tell you.
Posted on Apr 18, 2008
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Have gigaset 2420, two base stations and 8 handsets all thru house, I am trying to register handsets to base stations after moving around to new areas, have de-registered handsets and base stations and now...
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 18, 2011 | Siemens Gigaset 2420 Cordless Phone
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Cd135 philips.
The handset is not ‘registered’ with the based unit.
By default, the Master PIN is 0000.
  1. On the base station, press and hold The paging key for approximately 5 seconds.
  2. On the handset, press Menu key,
  3. scroll : to ADVANCE SET and press (Menu) OK,
  4. scroll : to REGISTRATION and press (Menu) OK.
Note: If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
  1. Enter the Master PIN when prompted and press (Menu) OK to confirm.
http://www.p4c.philips.com/files/c/cd2452b_05/cd2452b_05_dfu_eng.pdf
Mar 18, 2009 | Philips 2252 Twin Cordless Phone
Initializing
The hand-sets are not registered with the base-station. Reset system by: remove batteries, unplug base station, disconnect batteries in all hand sets. Wait 15 minutes. Reinstall batteries in hand sets. Reinstall batteries in base station, plug base station in. Place each hand set in the base station until it automatically registers (usually immediately, or within 1 minute or so).
If that doesn't fix the problem, if possible, return the system to where you bought it for exchange or refund. If that isn't an option, call Thompson help line. They are not particularly knowledgeable, but will authorize a return to the a repair center. The process is slow...
My experience: The two hand sets that came with my system worked perfectly, but none of the three additional handsets I purchased would register. The three additional handsets I purchased were the last three on the my retailer's shelf, so, retail exchange wasn't an option. I contacted Thompson and they authorized return for repair or replacement. The repair center received my handsets on October 29, 2008. Its now November 27, 2008 and I'm still waiting.
Mar 03, 2008 | GE 28128EE2 Phone
Phillips phone cd445
On the hand set:
- menu button - ADVANCED SET - REGISTRATION - base 1
- pin # is 0000 (default)
On the base station and the base station handset - press and hold for at least (3) seconds, at the same time:
- on base - the intercom button
- on base handset - menu button
It's in the manual but you need a magnifying glass to read it.
Dec 30, 2007 | Lands Phones
Connected then Disconnected!!!
that could mean your headset is not charging. make sure the light is doing what it is supposed to when charging. you probably have a defective charger. happened to me. you could try pairing it with another phone to see how long it lasts. I found the Moto HS850 to be the only good, reliable one.
Jul 09, 2007 | Motorola Mobility H500 Wireless Headset
Lands Phones Logo
134 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
