SOURCE: My Magic Chef gas oven thermostat is not working
ther is a temp sensor that goes from the control valve to the oven,this may be the problem, make sure sensor probe is tight where it screws into the gas valve and other end is not just hanging in the oven, it attaches to the top of oven,if it's where it's supose to be, I'd change that first
SOURCE: Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
SOURCE: Need to calibrate oven
The model number you listed isn't in the current or 'retired' products list.
If you find that F60 is in error, you should be able to download a manual here:
Vulcan-Hart
SOURCE: oven doesn't get to set temperature. I turn it on
You dont mention model so if its electronic control then you need to replace the thermister first and if the problem insist then the PCB Board.
If it is a mechanical the just replace the oven thermostat.
SOURCE: Having just converted my Vulcan
The oven safety valve has to be cranked down for propane.
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft.
look at the back of the knob and note the current setting before making any
adjustment. The knob is factory
set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP
knob
2. Loosen both screws
on back of the knob
3. Adjust lower screw
so it moves in the desired direction.
You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN
TEMP knob to the oven.
Re-check oven performance and make the
necessary adjustments accordingly.
