Still won't work
Thanks for your quick reply, but we already tried unplugging it for a day and a half and still have the same problem. Also the tv inputs are only showing antennae A and antennae B, When there should be three other input options. We've always been able to go to 5 different inputs but now there's only 2. If you go to add/delete channel, it shows the picture in a small box in the upper rt corner, but it won't go back to the full screen. We've tried going through the menu options and nothing works to get it back to normal. Is there any other way to reset it besides unplugging it? Or is there a certain screen or option we should look for to take it out of that setting? Please leave any tips or ideas, at this point we'll try anything. Thanks again.
-Jessica
    Brigadier General:
  • 6,966 Answers
Hi again,
This forum has much info re Mitsubishi PTVs. Nonetheless, an excerpt from there....
1.Set the Layer Switch at the top of the Mitsubishi Remote to TV.
2.Press and hold the POWER button, and while holding the power button enter 090.
3.Now the remote should function like this:
Power = Power On Discreet
Stop = Power Off Discreet
Pause = AV Reset
Pressing INPUT followed by:
PIP = DTV
1 = Input 1
2 = Input 2
3 = Input 3
4 = Input 4
5 = DVD / Component 1
6 = Component 2
SQV = Input STB
QV = Input VGA
PIP CH Up = Antenna A
PIP CH Down = Antenna B
4.When done, press and hold the POWER button and enter code 000 to return to the standard remote functions
Posted on Apr 17, 2008
Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
Apr 13, 2013 | Televison & Video
Hi, i am having problems with my TV since day
Hello sir Ibsen,
The first thing I suggest is to check the power cord and its connection if the light indicator on the front of TV won't turn on..Used multimeter or volt meter (range to AC) to measure the voltage..If no voltage,replace the power cord because the cord have internal wire break or open connection that can't visually check..
If the power cord is good,the possible problem is power supply board inside..
It cost $89.95 to this site http://www.shopjimmy.com/lg-6871qih001a-power-supply-unit.htm
But before you decided to replace the power supply board please try to reset or reconnect all connectors on all boards inside specially on power supply unit..
Also I remind you when the TV already open the warranty will void...
If you more queries and clarification please feel free to reply to this tread..
Hope this solution will be helpful..Thanks for using fixya marketplace and choosing my service..
Feb 21, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
The fridge just keeps running, it?s been two day already
Doubt anything is wrong here- let it run. These run 80% of the time anyway. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Aug 26, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
