Question about Iomega 32883 40 GB Hard Drive
Iomega external hard drive
This hard drive has a broken usb socket on the power supply board. can this board be bought as a spare part. all data on the drive is needed
  • john mackenzie Apr 17, 2008
    thanks Boff1. I am not sure if just replacing the USB port will fix the problem. I was hoping to find a source of a replacement power supply board since it all unplugs neatly from the hard drive.I have keyed in all the numbers printed on the board but searches did not find anything. The guy it belongs to seems to think there might be something more at fault than just the socket.I managed to reset the pins to make better contact with the cable socket, but the plastic "guide " is missing from the socket on the board. He has just taken it home to try it back in the drive
    Thanks for your help.
    Sergeant:
    Champion:
  • 333 Answers
  • boff1 Apr 17, 2008
    If the plastic is missing he may have connected it the wrong way around!. Does not seem like good news for the power supply.
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
I have seagate 500gb sata freeagent. usb port broken. need to buy the pcb connector because I dont think i could solder back the broken usb port to the board. anybody know where to order?
I believe you are looking for this: USB Mini-B (5-pin) you are looking for the "socket"
Here is a list of products to choose from:
https://www.alliedelec.com/search/searchresults.aspx?N=0&Ntt=USB+Mini+B&Ntk=Primary&i=0&sw=n
Please note; This will be extremely hard. most of those products have no pictures and you are not sure exactly what you are getting, luckily they are pretty cheap so i would recommend getting a couple that sound right.
Good luck, be careful.
Hope this Helps.
Mar 19, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I getting error 'USB device has malfuntioned and Windows does not recognize it" when I attach my transcend storejet 25 mobile to the computer. I have critical data in it and need somehow to get the...
Hi, most external hard drives come with a seperate power supply, the exception is "pocket" externals which some have the ability to run from the USB socket alone. They have laptop drives in them. Many of these drives come with a USB cable that occupies 2 USB sockets in order to obtain enough ppower to run. (Or a second cable that occupies a second USB with a power plug on the end for a drive. They will often not run on one socket. If your device came with a double USB lead then use this. If it came with an external power supply then use it as well as the USB lead. Try the same on another PC just to confirm the USB sockets on the one you currently use are ok or try a different device to prove correct function.
If all this fails to get your drive running then the drive itself is probably faulty. Is it under guarantee? If so then you can get a replacement. This will lose your data though as the guarantee does not cover stored information. In this situation, is the data more important than the drive? If very important, buy a replacement empty external drive case, remove your drive from the original case (voiding the warranty) and fit the drive in the new case and try again. If it now works you have a dead interface board in the old case, if still not working you have a faulty hard drive. Does the drive click continouously? If it spins then you could try data recovery software or run "HDD regenerator 1.71" on it to fix potentially bad sectors and try again. This is a time consuming process but if the data you need is saved then it is worth it!
I hope this helps
Steve at Olive country Computers.
Feb 20, 2011 | Transcend USA 120GB Storejet 2.5" SATA -...
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
Hi there, I have a Iomega drive and the power supply is no longer working. I am struggling to get a power supply replacement. Any suggestions? Does anyone know where can I buy a spare one from? Thanks
Not sure which HDD you have, but you can find your power supply here:
http://go.iomega.com/en-us/products/external-hard-drive-portable/accessories-for-portable-hard-drives/accessories/?partner=4760
Oct 31, 2010 | Computers & Internet
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega Prestige 1.5TB external hard drive won't start-up properly
Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
May 15, 2009 | Iomega 1.5TB Desktop USB Hard Drive
Iomega 32883 40 GB Hard Drive Logo
176 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
