Question about Pioneer Audio Players & Recorders
I am searching for speaker plugs for a pioneer prelude 4000A amplifier it is 1974 to 1976 model
After trying for days and not getting anywhere, then going to your site and discovering that I needed to spend more money than I could afford. I made a set. Thank you any way
Sincerely
0ztotp
Posted on Apr 18, 2008
I have 2 12" Pioneer TS-W3003D4 subs and I wanted to know can a Pioneer GM-D8500M run them?
pretty much any amplifier can run any sub, so the question is not weather or not the amp can run them, it is how well the amp can run them. Those Pioneer subs are dual VC models and are rated at 600 watts RMS. You have two, so that would be about 1200 watts of RMS power you will need in order to power the subs correctly and to optimum efficiency. The amplifier model you have is rated at 600 watts RMS for a single channel at the lowest stable impendence. That power coming from the amp will be split two ways between the subs and divide the power to each speaker. So each speaker will be receiving 300 watts of power. So in short yes, your amp will power those subs, but they will only be operating at half their rated power. Your amp will be running at maximum power so it might get a little warm after a while. make sure you wire it correctly and keep the amp well ventilated if you decide to push it that hard. if you need help on how to wire them search the web for wiring options by typing into Google " how to wire two dual voice coil subs into amp". There you will find plenty of illustrations to help you decide.
Aug 25, 2015 | Pioneer Car Audio & Video
I have buy a amplifier of pioneer model vsx-rs319v-k. My question is that can I please the bose acustimass 6 series 111. please let me know by email : sabree_7111@yahoo.com
Bose speakers are specifically designed to be used in conjunction with the Bose Acustimas Power Module and won't work properly just as ordinary loudspeakers connected to the Pioneer amplifier
You could connect the Bose Acustimass module to the auxiliary output of the Pioneer or via the HDMI repeater. However, if you do this you will still need a set of loud speakers connected to the speaker outputs of the Pioneer.
Feb 25, 2011 | Pioneer Audio Players & Recorders
When we connected pa-6000a amp. to four speakers with impedence 19 ohm ( with matching tr), as in the manual , the temp. sensed on the body is very high while we put the amp. on fan ventilated panel
19 ohm - is very low :( - are you using a Impeandace meter to measure this -
Can you please email me the types of speakers and transformer used on the speakers
rghanem@bigpond.com
I am a services aget for Inter-M in Sydney Australia
Aug 06, 2010 | Inter-M PA-4000A Amplifier
Adding subwoofer
Hello dongurian,
You can add the Bass600 even if your Pioneer does not have any premap outputs. The Bass600 has speaker level inputs and you should have gotten a keyed plug with pigtail wires to attach to the speaker output. Or, you can use a line-out converter if desired.
Hope this helps.
Aug 13, 2009 | Boss AUDIO SYSTEMS BASS600 Car Audio...
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Jul 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
All I want is two speaker plugs to suit a pioneer sterio amplifier model SA-500A
To whom it may concern, I am sorry but I was able to find the two plugs I was looking for in my junk draw . thanking you for your concern regards theeich.
Apr 23, 2008 | Pioneer Audio Players & Recorders
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
56 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
