Question about Brother DCP 115C All-In-One InkJet Printer
My printer have problem
Hello
Please can you help my brother printer machine DCP-115C have printer problem showing error 46 and the red light still flashing but the printer screen appear trouble shooting
e-mail syedinabi@yahoo.com
  • 832 Answers
You need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Posted on Apr 20, 2008
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother DCP 115C All-In-One InkJet Printer
Hi, i am from India and have a Brother DCP-165C Printer. Now i am facing problem with my Brother DCP-165C Printer. It is showing " Machine Error 46" What is this problem & how can i get a solution. ...
Machine Error 46 indicates that the ink absorber pad is full and needs replacing. You will need an engineer to replace this.
If your machine is out of warranty, please contact Brother Customer Service:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
M-F, 9:00am to 8:00pm Eastern Time
Jan 19, 2014 | Brother DCP-330C All-In-One InkJet Printer
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
My printer DCP-115C show out the error code "Machine error 4F". How to solve it?
Unfortunately this is an error in print head and need replace.New print head will cost you as much more then new printer then think about new printer.
Nov 05, 2009 | Brother DCP 115C All-In-One InkJet Printer
Error 46
did you already fix it? my printer is also dcp 130 c... it says unable to clean 46
thannks
Aug 08, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C USB Printer
plz search this forum for error 46 or "unable to clean". It has been written many times ;-)
May 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Re-set for DCP-115C after replacing ink reservoir
if u replace ink manually, the priter may no longer work. bcoz bubbles will damage the cartage. thak you
Apr 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
The error messageunable to init
you have to replace the print head.
But to be honest: its cheaper to buy a new dcp 135c or 130c with warranty and new carts incl.....
Mar 12, 2008 | Brother DCP 115C All-In-One InkJet Printer
Canon DCP 115c
if your printer is a BROTHER which shows error 46 (unable to clean) it can be fixed:
you need a new waistink absorber which can be purchased from a brother service partner near your home (see brother homepage). After replacing there must a eeprom rest be done.
Feb 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
390 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
