I need the settings for a d-link dkt-410 to virgin broadband.the router is recognised by the laptop,but the router is not recognised by the provider.as you can see im no expert! thanks
  • 472 Answers
With this you will have to reset the Virgin box to deregister the Mac address it holds.
Connect the computer to the router and have both turned on, connect the router to the Virgin (always wated to type that) and then unplug the power from the virgin (this is getting better all the time)
Leave it unplugged for 15 minutes, then power it back up with the router and computer already running.
Log into the router and check it has been assigned an IP address by the Virgin (yeah, I had to get one last one in)
Good luck, post back if it still gives you grief.
Posted on Apr 17, 2008
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
How much to buy one
USB Kit DIR-300 Broadband Router & DWA-110 USB Adapter DKT-USBG - D-LINK WIRELESS G ROUTER & USB KIT $94
D-Link DIR-300 Wireless G 54MBPS Broadband Router, with 4-Port 10/100MBPS Swich $63
Oct 25, 2010 | D-Link DIR-300 Wireless Router
Dkt-410 wireless router keeps dropping connection
Make sure that your computer works properly when connected directly to the modem without the router.
If that is working properly and not dropping the connection then the Internet service is working.
If it is dropping, then you will need to check the modem or call ISP.
If your computer works properly when connected directly to the modem then you will need to check the settings of the router. I think you will need to upgrade the Firmware of the router.
For this you will need to connect a computer to the router and open the set up page of the router. After upgrading the firmware, you will need to reset and reconfigure the router.
Click here
for more information about the routers and networks
Jan 31, 2010 | D-Link (DI-711) Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Unable to get laptop to connect to the internet.
I have resolved the problem by doing a system restore. I set the computer to a previous date and this seems to have sorted out the problem. I guess that I may have had a software confliction.
Many thanks.
Nov 27, 2008 | 2wire HomePortal® 1800HW Router...
I've just purchased DKT-110 wireless G starter kit.
The Internet/WAN port on the router should be connected to your cable modem's internet port.
Then on your laptop, you should click on "View available wirless networks", your Router should show up there. click connect and you should be able to surf.
Note::The USB DWA 111 should be connected to your laptop and the drivers installed
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
ISP
I have a feeling I might be able to find the router setup information if you can tell me the correct answer to the prompts needing answered by this link
Virgin Media Broadband Help
The model number of the Belkin router may be of interest if detailed configuration instructions are required and because there is the a report of an issue with a specific belkin router model on the Virgin Media site that appears to require a firmware update to work well with that particular internet service.
Dec 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
