Question about Samsung Washing Machines
Door switch on my samsung j1045 front loader washing machine playing up, need another one please.. Ray.
I found a site that was not only free as it should be but has every jolly part under the sun and customer service as well. So naturally they instantly got my business.. Ray.
Posted on Apr 18, 2008
SOURCE:
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
I have a front loader samsung j1045.it just wont go on most cycles,so i was just using it on colours.now its showing the error de after a few minutes and beeping..please help?? Nan T
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 14, 2011 | Washing Machines
Can i use any drive belt on a front load samsung wasing machine model j1045
This is the belt number:
SAMSUNG FRONT LOADER DRIVE BELT 6602-001072 (1050323)
And this is just one source for the belt:
http://cgi.ebay.co.uk/SAMSUNG-FRONT-LOADER-DRIVE-BELT-6602-001072-1050323-/250632182892
Thanks for choosing FixYa,
Kelly
Apr 08, 2011 | Samsung Kitchen Ranges
I have samsung J1045 front loader washing machine, which i can switch on the power but none of the sitches work?
this would be due to either a bad touch pad or a bad electronic control or you have some wiring that has come disconnected on the inside of the control. Disassemble the control as a whole and check all the wired connectors you may find you can just replace the control and the touch pad would come as the same piece that your order if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
Mar 28, 2011 | Samsung Washing Machines
Front loader iwll not start DE error code Samsung model J1045
this means door error sometimes you have to rewire it, replace the computer & the door interlock all at the same time to fix it try the door interlock first beware sometimes if you dont do it all at once the new part gets taken out as well so fingers crossed its just the door interlock.best option to have samsung service agent out to check out with diagnostic tools.
Jan 13, 2011 | Samsung WF337AA Front Load Washer
Washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Feb 23, 2010 | Washing Machines
I have a Samsung j1045 frontloader washer and it turns on but would not move to any wash cycle or turn off.
I have a Samsung j1045 front load washer and once turned on, it wouldnt move to any washing cycle or turn off. I would have to unplug the cord from the jack to prevent any danger. Please help me and give me a solution as I have a mountain load of washing to do.
Nov 02, 2008 | Washing Machines
I can not seem to balace the washer- it dances around the room on spin. front loader j1045 6mths old
Has anything changed? have you moved it? is it level? Check the level of it and if it is infact NOT level make it so.. If it IS level I would not play with it.. get a warranty repair tech out..
Hope this helps
May 30, 2008 | Samsung Washing Machines
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
Washing Machines Logo
537 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
