Question about Casio Parts Cash Register PC Desktop
PEA is the screen...All the are locked and even if i pull the plug out it still comes up.... How do i get rid of it??
  • 737 Answers
Hi. Sorry, I don't understand. Does the display only show 'PEA'? I have never had this. Please let me know the model number.
Mark
Posted on Jun 23, 2008
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Hi There my SAM4S is showing PEA on the screen. All the buttons are locked also. I have unplugged and it doesn't change anything? Can you help?
I have a SAM4s register. When it read "PEA" all I did was pull the receipt paper. It seemed to be jammed. Worked for me.
Sep 07, 2011 | Casio Parts Cash Register PC Desktop
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
How to get rid of that lock icon on my screen
The problem was my monitor, not Webroot. The expiration of SpySweeper was merely a coincidence. I hooked up a different monitor and the problem went away. Apparently my monitor is on the flake, so I am replacing it... Problem solved.
Jun 25, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Garbage disposal doesn't drain
Sometimes what happens is that when they install a garbage disposal the pipe coming out of it ends up being lower than the pipe exiting the pea trap thru the wall under the sink. If it is a dual kitchen sink this is very common. Being lower than the exiting pipe causes water to stay in the bottom of the disposal and not just the pea trap. If you have a side by side sink in the kitchen and the water is backing up in the other sink also then more than likely the pea trap has a blockage. It is not common for the straight line from the pea trap going thru the wall to become blocked, but it does sometimes happen. The biggest cause of this is poring hot grease down the drain. It is just about the point that it cools enough, sticks and hardens plugging the drain pipe.
You probably should have a plumber look at it and make sure everything is running downhill under the sink. The only place that water should set in the plumbing is in the pea trap so that odor from the sewer does not come up into the house. Without actually seeing it, it is hard to tell exactly what is happening. The pea trap is easy to clean, put a really big pan under the trap, make sure you have emptied as much water out of the sink as you can, then with a big pair of channel locks unscrew the two nuts that hold the pea trap in place and let the fluid drain from it, then finish unscrewing it from the pipe. You can then clean it out and check the pipe thru the wall for blockage. When reassembling it, screw it all together loosely and then move the pieces around while hand tightening each joint so the they have no pressure on them, then use the channel locks to finish tightening the nuts. Don't over tighten them because they have nylon seals in them that compress to make the seal. Just tight enough to seal and not leak. You should be up and running again unless the plug-up is farther down the wall pipe. Good Luck, RAC
Apr 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Protect screen on my sharp cd-ba150
that is your movement protection. In your manual it says how to get rid of it. mostelikely you have to push power and open button at same time
Jul 08, 2008 | Sharp CD-C662 Shelf System
Casio Parts Cash Register PC Desktop Logo
148 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
