Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Recording using 5.1 live sound card
Hi am having trouble during recording one side keeps cutting out to a whisper with static like a loose connection
  • 2 more comments
  • rob67462 Apr 18, 2008
    hi
    had card for few years now and have replaced cables
    problem just comes and goes could it be a driver problem as using xp pro
    hi
    no not using mike only line in
  • rob67462 Apr 20, 2008
    tried this but wouldnt recognise my card
    drivers that im using are dated after the update
  • rob67462 Apr 26, 2008
    problem exists in both headphones and speakers but have tried to fiddle with cables and it does seem to affect it but when i stop it just comes back. so have changed cables problem wont go away
  • Creative Labs Master
  • 13,433 Answers
Hey, is the card brand new?
Posted on Apr 17, 2008
    Genius:
  • 1,142 Answers
Did you check the cables connected are not damaged
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 17, 2008
    In case you have the mic connected too and is enabled which might be causing the interference please disable the mic then the recording will not have any issue. Please try and let me know
  • Maanita Chadha
    Maanita Chadha Apr 23, 2008
    As you are getting the scratchy noise then it is 100% the connector of your speaker which is creating the problem, to identyfy that you can shake or move the cable you will come to know that its the speaker cable connector. you need to replace that.
    Dont forget to rate fixya
  • Maanita Chadha
    Try using a different speaker set or to test use a headphone you will be able to easily determine the issue
  • Maanita Chadha
    Maanita Chadha Apr 27, 2008
    In this case you need to check the windows audio settings that should be set to windows default and then you can see how it works
I have an ess 1969 pci audio card and i am hearing a faint static in the background. when i record audio it pops during playback. PLEASE HELP!!!!!!!
Just rmove the PCi soundcard, clean the gold contact points using a rubber eraser, untill the gold color appears again.
Put it back and it will work!
Feb 21, 2012 | Computers & Internet
It cuts tape off after a short time and says it's finished recording when it hasn't. Then I try to play it back and can't hear it - just a very faint whisper!
More is needed. What's IT that cuts off? Are you using the TT's Line Out or Phono Out (which is a 'faint whisper' by comparison. Many digital recording applications will assume extended perceived silence is the end of the program and just stop.
Jul 26, 2011 | ION Audio TAPE2PC Single Cassette Deck
Hi.. my name is Alex I have my us122 for about 5 years,but used it ones or twise becouse installation conflicts with my windowsXP.. last time I could get the sound out of it--was 2 years ago.. but...
Alex you have to get the drivers for it once you install it back into your computer. Depending on which operating system you are using I personally like XP for sound recording or playback cards. Less is best when mixing sound files no glitches you know what I mean. Now because of updates that happen all the time with any hardware you have to keep up with the updates go to the manufacturers web site and download the latest drivers always. 5 years ago was a while back in the computing world we live in and most likely or hopefully there is support for Win 7 for this card. If this is the system you are using if you have the install disc for this card reinstall it first. John
Jan 16, 2011 | Tascam US-122 Sound Card
There is static on the speakers all the time.
Hi
The static on the speakers can be caused due to many reasons. However, the most common trouble maker is a cut wire or loose connection. Try tweaking the sound settings before proceeding further.
If not resolved then, check whether all the connections are good and wires are not cut. Next thing to check is the power cord, try changing the power socket to see if it is due to the electrical noise caused by power socket.
The last thing to check for is the sound card. Use a headphone and insert it into the same jack where your speakers are inserted and check if you still can hear the static. If yes then the sound card is faulty and if no then there is an internal circuitry issue with your speakers. Please post back for any assistance.
Daniel Scott
Jun 20, 2010 | Creative Labs SOUNDBLASTER AUDIGY2 PCI...
Music cuts out for a split second randomely
u r facing the problem of buffer down of pcb
ju must change ur processor and ram too than u see that ur system working properly
Jul 26, 2009 | Rane Serato Scratch Live Computer DJ...
RECORDING GUITAR USING AUDIOPHILE FIREWIRE AND GUITAR RIG 3
I've ran the audio in on my sound card to my mixer and had the guitar on the mic in.  I've also ran the line in to a small cracker amp.  Keep it turned down. If I would directly connect it use an adaptor.  I haven't tried using a 1/4 to 1/8 adapter and directly connected to it as I wanted to control the tone. I don't see why it wouldn't work.  Keep everything muted and turned all the way down when you first connect it.  Then start raising volumes slowly  I will try and report back As far as spdif you're just recording analog to digital conversion.  I get more realisitc sound just keeping it analog til it hits my line in.  Have a quality sound card.  Not some walmart special.  I use Adobe Audition 1.5 to multichannel record.
Sep 08, 2008 | M-Audio Audiophile External Sound System
Nuendo/Cubase sound cuts off
I chased this same problem with a friend's laptop using Cubase. Additionally, he had several recurring pops at high end, in regular intervals, with 23 seconds of trouble free gaps in between incidents. Eliminated hardware problems, so I contacted some Cubase user groups and they indicated their older software was not compliant with the newest hardware... in other words, they suggested he buy a newer version.... He did (gasp, sticker shock... the horror) and the problem disappeared. Might be all that is wrong for yours, if your desktop has newer hardware and older version of Cubase.
Jan 31, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Recording not right
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Oct 25, 2007 | Behringer (UCA202) Sound Card
CD recorder keeps stopping during recording
I think that, considering that is brand new and under warranty, why bother with messin' inside system with risk of loosing warranty.
Oct 09, 2007 | Audio Players & Recorders
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
138 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Shawn DuRee
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
