Question about Nokia E61 Smartphone
Connection error form time to time i receive connection error. Is it carrier problem or cel problem?
IT is a carrier problem. If it gets repeated toomany times ... simply switch off and restart.
Posted on Apr 17, 2008
Isuzu 2.petrol van.engine lite flashing on dashboard.why?
three posts, now, all on a car we dont have in USA.
why not add to one post ?
this time the CEL glows.
that means scan it.
or if no tools
means get car serviced. 1988 to now.
all cars. the lamp literately means
the engine brains sees gross errors.
and is reporting them in the form of DTC errors.
it means scan it to see them.
or get it fixed.
Dec 05, 2016 | Isuzu Cars & Trucks
What is code E
Watch and see what it is blinking, since the "E" stands for error code and AFTER the "E" blinks, usually a number also blinks. For example,
"E" then "1" means there is no mobile network signal. Try to move to a different location where you get a better signal.
Error code 2 usually means there is some interference. Again, try a different location.
Error code 3 and 4 usually means the Coverage Unit temporarily stopped working and has switched to a low power mode because the environment is too warm. Move to a cooler location.
Error code 5 can mean the Cel-Fi system cannot find the network that it was programmed to operate on. Your Cel-Fi system will only operate in the home network of the carrier who issued the device and cannot be moved from one city to another. Try returning the Cel-Fi system to the city or market area in which it was originally distributed for use.
I hope that helps!
Feb 28, 2015 | Cell Phones
Unsubscribe to stop charges on my cellphone
I had the same problem with cel phone cahrges. My where texts that cost me .95 a pop. I called my carrier (verizon) and they texted me the number I needed to unsubscribe to the toll texts I was receiving. Hope this helps.
Aug 19, 2012 | Cars & Trucks
My phone is looking for PUK CODE but i cant find it,can you help?
The PUK (Personal Unlocking Key) code is a code assigned to your carrier's sim card. Its usually written on the form you received when you purchased the sim card, or on the shell the sim card was attached to. If you don't have it, just go to your carrier ( eg.AT&T, T Mobile) and provide your sim card number. Once its under your name, they will provide you with the PUK code.
(Remember most sim cards have a default number of incorrect times you can enter an incorrect code before it destroys the sim, so if you don't know it, dont enter anthing until you receive it from your carrier)
Apr 21, 2011 | Nokia 1600 Cellular Phone
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
Error #1200----help cannot receive Fax but can send them
Hi There
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Nokia E61 Smartphone Logo
Top Nokia Computers & Internet Experts
Clive Gray
Brian Sullivan
Brian Sullivan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
