Question about SanDisk Sansa e200 MP3 Player
I would like to convert the voice recorded material saved in my sandisk into text on my computer is that possible?
  • SanDisk Master
  • 13,433 Answers
Easyest way would be to type it into a text file, everything you hear.
or you can probably get some software to do that
http://www.brothersoft.com/wave-to-text-7887.html
Posted on Apr 17, 2008
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
Sansa C240won't let me transfer voice recordings to computer
You may need to use the converter if the conversion of format is required.you can download the converter from the internet.
Aug 08, 2009 | SanDisk Sansa c240 MP3 Player
Saving images
Basically what it is saying in that paragraph is that you can also use this device as a flash dfrive and save images, text documents, etc. When the device is connected to your computer it is seen by the computer as a disk drive. You would access that disk drive and copy any images or files into any one of the DSS_FLD folders that you see when you access the drive letter that represents the recorder.
Jan 03, 2009 | Olympus WS-110 Digital Voice Recorder
Need to download from mp3 player to a disc, is it possible
First, you will have to hook your Sansa to your computer. Then, you will need to double-click My Computer, double-click the icon or drive letter that corresponds to your Sansa, and then open the Voice folder. Find the recording that you want to back up and drag it to your desktop or other temporary location on your computer. Then you will most likely want to convert the recorded WAV file to mp3 format using Media Monkey or some other free conversion tool. Then use disc-burning software like Roxio or Nero to burn the converted file to CD. Have fun!
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Transfer recordings on my Digital wave player on my computer to a CD
on xp, you will need to convert the recordings into 16 bit wave file through the sound recorder on your computer... you may need to call olympus for more details
Sep 23, 2008 | Olympus VN-2100PC Digital Voice Recorder
Olympus VN-3100pc
on Windows XP, you will need to convert those files into 16bit cd audio quality. You can do this thru Sound Recorder on the computer. Just make that you change the file name before converting. Open up sound recorder, open up file, save as, convert, then change quality to cd quality then ok. After it is saved in 16 bit format, open Windows Media Player and then burn.
Aug 24, 2008 | Olympus VN-3100PC Digital Voice Recorder
Haw can I record and save? on SANSA of SanDisk
ok so go to menu record and then finish recording itll ask you if you want to
May 29, 2008 | SanDisk Sansa m240 MP3 Player
Training my audio recorder to my voice in order to convert sound to text
buen dia, necesito el motor de reconocimiento de voz en español para mi grabadora, ya que no puedo usar la funcion de sonido a texto
Apr 17, 2008 | Panasonic RR-US395 Digital Voice Recorder
Voice record
IT WILL SAVE AS EITHER .AMR OR .AAC FILE WHICH BOTH CAN BE CONVERTED BY TOTAL CONVERTER AND CAN THEN BE BURNED TO CD..
IT CAN BE TRANSFERRED THRU BT BY SEND OPTION.
REMIND THE MAN FOREVER
PLEASE DONT FORGET TO RATE ME. ITS A MATTER OF SINGLE CLICK OF UR MOUSE
Mar 10, 2008 | Motorola Mobility V525 Cellular Phone
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
