Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We checked the cable connection on another tv and it worked fine so it's not our cable service or the actual cable line. We confirmed the cable is connected firmly to the tv set. Once we confirmed the cable service was ok and reconnected the line, the sound stopped working for the DVD player.
  • 13,433 Answers
The signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Posted on Apr 17, 2008
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
LG 32LB9D lost channels
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 16, 2017 | LG 32LB9D TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When tv is turned on, screen shows white w/ blue logo, then shows "VGA" and "no signal" on a blue screen. After a minute it turns off. We cannot get a picture. We have a Time Warner...
Right now the TV is set to accept the video signal from PC through the VGA port so when it does not see the video signal from the VGA port, the TV will go into shutdown or standby mode. You need to change the input to be where the cable box is connected to using INPUT or SOURCE button on the remote.
What kind of connection are you using to make the connection between the TV and the cable box?
Please clarify. Make and model of the TV?
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2011 | Televison & Video
My Dell LCD Model W2606C will not process a cable TV signal suddenly. All else seems normal. Any idea what could cause that to happen.
Welcome to Fixya. If your tv cant process a TV signal most likely you are on the wrong input. We can check if the input that has been set to the LCD is correct. Can you please provide if the LCD is connected to a cable box and what cable is connect from the box to the LCD.
Thanks
Jun 22, 2011 | Computers & Internet
We cannot link our ps3 to the tv. All of the cords are in place, but the tv is still showing "no signal"
Regular tv imcomming broadcasting tv signal still work?Yes.Tries all tv video inputs signals like 1,2,3 so on to make sure ur tv video signal input is in the wright tv video input.Or the cable set u are using right now could be bad too.Tries websites like Amazon.com,Ebay.com to buy a new set of cable for the replacement.
Apr 24, 2011 | Tatung V32FLBB 32 in. LCD Television
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Jan 22, 2011 | Sanyo DS31520 31" TV
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a Polaroid FLM-373B 37 " tv and I get a blue screen with "No Signal" in the top corner. Cant seem to get it to find a cable signal, dvd signal or anything. I have successfully...
That situation clearly indicates that no signal is coming to the set in its present setting. Have you checked to make sure that the tv's input is set on the right input setting. Mine always defaults to "Antenna" which drives me nuts cause I get that big blue screen with "no signal". It seems to do that at the slightest provocation, too. After 5 years, I still have to think twice before checking it. If that is not it, make sure that the cables are plugged in. If that doesn't fix it try another type of input such as HDMI or S video, composite, etc - one that you are not using. Don't forget to switch the input to it. Good luck!
Nov 06, 2010 | Polaroid FLM-3732 Television
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
