Question about Microsoft Xbox 360 Console
Can you use a xbox 360 european power brick (220v) on a USA xbox 360 in europe
Can you use a xbox 360 european power brick (220v) on a USxbox 360 in europe........my power brick has completly failed. it would be to much of a hassle to ship it back to the usa.so i thought i could get a european brick since im here and it could convert the 110v of the us console to 220v with out a voltage converter
  • Anonymous May 11, 2009
    i am in australia, and i need to know if i can buy a 220v brick from here and use it on my canadian xbox. will this blow up my xbox 360.
You must see the data on the brick label. If it says the correct tension (tension = voltage), yes, you can. But be careful because the Xbox's have three tipes of tension. It depends on the motherboard. If the mother is a Falcon, the tension is 14.2 V, but if it is a new Jasper, the tension is 12.1 V.
Posted on Mar 13, 2009
  • 85 Answers
If you do you will damage the internal components and it will break. Do not try it.
Posted on Apr 17, 2008
I just moved to France and brought my Juki TL-2010Q from the USA. I plugged it in with a European adaptor and it blew the fuse? Is it fixable? Where do I get a replacement fuse? Thank you! Suzanne
Did you mean an 'adaptor' (as in two-pin to 3-pin) or a transformer ?
It is a DIFFERENT electrical system in Europe to the USA.
The USA is 110v and Europe is 240 or 220v. The machine is
probably burned out. You would need to take it to a dealer to be checked. You can ONLY use USA electrical equipment with a TRANSFORMER, so that it can function on the different European electrical system. Good luck !
Sep 12, 2016 | Juki Sewing Machines
I plugged my xbox 360 SLIM into a 220v using a 110v power brick and it blew up is the xbox ok?
Possibly. There is no way to tel until you replace the power adapter and connect it to an appropriate power source.
Oct 11, 2014 | Microsoft Xbox 360 Console
I plugged my xbox 360 into 220v and the power brick blew would the console be damaged too?
No way to tell until you try it. You could consider purchasing a used power brick from ebay to test it.
Jan 31, 2014 | Microsoft Xbox 360 Console
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
Dec 01, 2011 | Miele W1926A Front Load Washer
Hi i have xbox 360. it was on 110volt some on plugged into 220v. it seems it has blown the power supply. can anybody help me to to fix this problem. any reply will be highly appreciated. thanks
Hi, the power brick on your 360 is designed to "blow" in the event of a power surge or in this case to much power. Take your power brick and try to plug it in to someone else's 360 and see if it works. If it doesn't then you need to buy a new power brick ( a cheap alternative to replacing the 360). But, if it still works then you may have totally burned your 360 since they don't have an internal fuse. At that point I would take it to a repair shop and let them look at it to see the extent of the damage and give you an idea as how much it is to repair.
Aug 17, 2009 | Microsoft Xbox 360 Console
Disc unreadable
depending on the game it may be region restricted, meaning it will not play in European xbox 360
Aug 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 issues
Hi Demirtas,
I'll try and help you out...
1.  You could try the paper clip method but I wouldn't recommend it, if you are able to take your console to a near by games store they may open it for you using one of their power bricks...
2.  You'd have to run the correct voltage through the console or you could cause irreversible damage to the unit, you don't want to fry the motherboard!  You could pick up a pre-owned brick or use a voltage converter...
3. Yes you can use any power brick as long as the voltage is correct..
I hope this helps a bit, sorry if not.  Please rate!
Thank you!
Apr 17, 2008 | Microsoft Xbox 360 Console
Power brick red light
yeah you definitly need to have a uk to usa power converter. you guys run on 220V which would create way more current then needed which is why the power supply blew. I hope you didnt fry any internal parts in the 360. You need to get a power converter that gives you 120V.
Dec 26, 2007 | Microsoft Xbox 360 Console
XBOX 360 Power Adapter
What happened when you switched on the console? I think the 360 is supposed to run from 240v (at least that's what it says on the power brick) 220v may not be enough to power the console. You may have damaged the console but I'm unsure as I've never run into this situation before. You could try another power brick making sure you use the correct voltage. I'm sorry if this isn't much help but please rate if at all useful, thanks!
www.360solutions.eamped.com
Nov 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
981 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
