Question about Microsoft Xbox 360 Console
Xbox 260 error 71
I put in game and in asked to update. selected yes update. update started and did not complete. now i get error 71 and red blinking light lower right quad appears.
  • choebox Apr 17, 2008
    Sorry, i meant 360. It's late and im typing in the dark on non-lit keyboard. Ihave tried the reset console several times with same error. I have also uplugged/replugged all the cables without same result. Have not tried the clear cache cause it goes into error right after logo screen. Please help.
  • choebox Apr 18, 2008
    is there a way to reset the 360 factory defaults?
You might wanna send it in to xbox but their system is down u might wanna call tommarrow here, 1-064-778-878
Posted on Apr 18, 2008
Put it in a towel and shake it n a circle IT WRKS
Error 71 it keeps freezing
from : http://forums.xbox-scene.com/index.php?showtopic=484726
E71:
Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally
Jan 05, 2012 | Video Game Consoles & Games
My xbox keeps freezing when I play my games then sometimes I get an E 71 error??? what do i need to do?
E71: Dashboard Error - Error within Xam.xex
Try resetting the console - Clear All Installed Game Updates and Console Cache
  2. Select "memory"
  6. Select Yes
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
If that doesn't fix it, you'll need to set up a repair with MS.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Jun 27, 2011 | Video Game Consoles & Games
Fallout 3 disc reading/load issues
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
Jan 27, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Error 71,what is that?when I load a game it loads,then screen goes black and says error 71
71 is usually cuased by a failed update that was installed or possibly a memory issue. Try these two soloutions and if they do not fix the issue, you have a hardware problem and you will need to send it in to Microsoft.
  2. Select "memory"
  6. Select Yes
Jan 23, 2010 | Microsoft Xbox 360 Console
Original xbox wont start up. while trying to start up, an error screen comes on and the light blinks red and green. a long red blink, and a short green blink
if there isn't a error code showing up on the screen then chances are your system is fried. You can put in a solderless mod chip for under $40 and save the system. Or you can go to the pawnshop and buy a used one. If you need more help let me know.
Sep 13, 2009 | Microsoft Xbox Console
1 red light can i fix this at home ? if so how.
--==Console Reset Codes==--
2. Select "memory"
6. Select Yes
Jun 26, 2009 | Microsoft Xbox 360 Console
E 71 error on xbox 360
Sorry timehrhart you've just copied a huge section from Xbox Scene forums without mentioning the Reset codes.
Back to the question - E71 is due to a dashboard update, most new Xbox consoles get this error due to missing a patch that was available to download when the new Xbox dashboard came about.
To fix this you have to clear all game updates and clear the console cache and update your console via Xbox Live. To do this on the old dashboard layout go to the 'System' blade and then Console / on the new dashboard go to 'My Xbox' tab and then go to the far right and choose the 'System Settings' and then Console and then go to the 'Memory' section. Press Y and enter this code - X,X, Left Bumper, Right Bumper, X,X.
You will get a message asking if you want to clear your cache, press Yes and just wait for it to do it's thing and it should come back to the dashboard. Now you have to update your console via Xbox Live and hopefully it should fix the problem.
If this should fail then you have to send your Xbox back to Microsoft for it to be fixed. Microsoft have extended the warranty of any Xbox to 3 years if it has the E71 or Red Ring of Death error, so hopefully you should be covered.
Mar 13, 2009 | Microsoft Xbox 360 Console
Error 71 on screen
this error is caused by a bad update. go to the system blade, select memory, press y on the HD symbol, press x,x,Left bumper, right bumper, x, x, a message will appear, select yes
Feb 21, 2009 | Microsoft Xbox 360 Console
XBOX 360 SOMETING DOES NOT SWITCH OFF AND PRESS THE POWER SWITCH
if your xbox 360 is one of the older ones or the first released xboxes then it could be the start of the 3rrod problem this type of error can occur when the motherboard starts warping and the solder joints are broken which can cause similar problems such as this. i would also try getting the very latest game you can and doing an update to see if this helps. you may also be able to download the update from www.xbox.com. burn the update to a dvd and then place the dvd inside your 360 and when asked if you want to update select yes and see if this helps.
Dec 11, 2008 | Microsoft Xbox 360 Console
Red light keeps flashing and it is showing an error screen that says E71
If the below doesn't work, you'l need to send it back to MSFT.
Clear All Installed Game Updates and Console CacheGo to the "system" blade
Select "memory"
Select Yes
Jun 17, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
341 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
