Hi I have a rca tv that has guide plus on it , But I have lost the remote and the demo keeps popping up. Is there a away to take it off without the remote control?
  • 149 Answers
Yes U can use volume up and down channels up and down and menu key as ok key look in the guide plus is and option to turn that of just play with if still having problems let me know and I' get the steps to get rid of
Posted on Apr 17, 2008
Turn off guide plus rca f19426 no remote
You must have its remote control to make this function OFF
Sep 01, 2012 | RCA F19426 19" TV
I have a RCA guide plus gemstar t.v.I have lost the set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
Sep 17, 2011 | RCA 36F530T 36" TV
Guide Plus keeps popping up when the remote is used to turn TV on
there should be a way to turn it off in the user menu. usually it's under setup.
Jan 10, 2009 | RCA Universal Remote Control
When I turn on my internet and TV with the universal remote the Guide Plus menu comes up as well and we can't get out of it without turning the TV off then on again manually. Is there anyway to program the...
1. When you cut on you tv the guide pops up.
2. On the tv remote there is a button that says "menu" hit that and the screen should go away, i just did it myself because i have my tv program with that Jumbo Universal Remote Control and just ran into that problem.
3. How to just program it out of the tv when its cut on all together, im on the hunt for that answer myself.
4. Try going to manufactures website and try trouble shooting for your make and model, that is what i am about to do right now. Cable tv has the guide so i don't need my tv to pop up its guide also.. you now.. good luck
Jan 05, 2009 | RCA 24F512T 24" TV
RCA GuidePlus Gemstar Universal Remote Control 242524
i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
Jun 08, 2008 | RCA Universal Remote Control
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Guide Plus Demo
I have serviced lots of these, and as far as I know the CTC203 chassis has nothing like this, nor did anything made by Thomson before or since, so I am mystified. Adjustments are made with the remote or the front panel buttons using software and there are no "pins," test connectors, switches, or anything similar present on it. Usually the Guide Plus stops working entirely (which is nice for most users, as it is just an annoyance). Now if you unplug your TV for long enough for its microprocessor to reset, it will start with the Guide Plus screen. This is by design and can't be stopped without modification. Corruption of the set's internal program causing something strange like this is possible, but unlikely. (It was a problem on earlier models). Leave your TV plugged in and see if this problem goes away. If this is not the cause, you will have to take it in for service. Any demo modes can be turned on or off with the remote or the buttons on the set.
Feb 24, 2007 | RCA F27649 27" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
