Question about Microsoft Windows Server Standard 2003 for PC
Windows Server... Problem:
Ok i can do this but, how ii wil get that option for sharing? that is my problem ok, can u please help?
What
Posted on May 04, 2008
    Scholar:
  • 160 Answers
Hello
1. Just Select the folder which you want to share
2. Right click on it and select the sharing and security option (this is different for different OS) and i have been saying for XP
Let me Know that you problem is solved and rate me as Fixya!
Posted on Apr 29, 2008
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Oct 11, 2016 | Xerox Office Equipment & Supplies
Tip
How to Stream Music from Windows 7 ? Share Media on Wireless Network
You can listen to your favorite music without having to carry your laptop everywhere by sharing your music library on a wireless network. Here is a tutorial to show how to stream music from one laptop to another. Using this method digital media such as videos and pictures can also be accessed from anywhere easily. By the following method you can listen music or view your photos or movies stored in your computer from different places in the network.
First we'll connect the server laptop to a wireless home network. This laptop has Windows 7 with Media player 12 and it has all the music, videos and media that you want to share. Right-click on the Internet notification area and select 'Open network and sharing center'. Now, click on 'Connect to a network' and from the list of networks, choose the preferred one and connect. Enter the secure network key when prompted.
Let's create a 'HomeGroup'. From 'Network and Sharing Center', click 'HomeGroup' and then 'What is a network location?'. You'll see a window with three options. Select the first one that says 'Home Network'. In the following window, select what you want to share and click 'Next'. Follow the onscreen instructions and Click 'Finish'.
In 'Network and Sharing Center', click 'Change Advanced Sharing Settings' and make the changes. Then go to 'Media Streaming Options' and allow people you want access to your files. Open Windows Media Player, go to 'Stream' and click 'Automatically allow devices to play my media'. The content you chose to share is now on this network.
To access this content on a client PC or laptop, first connect the machine to the same wireless network as the server laptop, using the previous procedure. Vista users can right click and directly select 'Connect to network'. Assuming that both laptops are in the same network, open Windows Media Player and see of you can find the shared server laptop in the left pane.
To find shared media on the network and to share media from the client PC, in WMP, right-click on Library and click 'Media Sharing'. Here, you can allow or deny access to other PCs and find the media you're looking for. Click 'OK' when you're done. Now, the server PC will appear in WMP and other functionalities will remain same. You're now ready to play the music which is stored on the server PC.
on Oct 04, 2010 | Computers & Internet
I have Windows Vista and Internet Explorer 9. Skype was fine and now won't even open. A small box comes up saying 'Skype has stopped working'. I have checked for updates. Help please!
Try this, (Vista & Win 7)
1. Close Skype
2. Exit the Skype icon from the system tray(at the bottom right of the screen)
3. Ensure that "Show hidden files and folders" is switch is check & enabled
(i). Start-> type "Run" & press Enter
(ii). Type "control folders" & click OK
(iii). Select the View tab & ensure the relevant entry is enabled
4. Locate the shared.xml file
(i). Start-> type "Run" & Press Enter
(ii). Type "%appdata%\skype" & click OK
(iii). Delete the "shared.xml file" - (without quotes)
Restart Skype, a new shared.xml file will be created.
Hope it will help.
Jun 02, 2011 | Computers & Internet
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Wifi server
Once you have setup the central sever you can right click either the harddrive(s) or individual folders and there should be an option to share (or sharing and security). Open that and it should be quite straightforward to setup permissions so all computers can access those network places.
Next on the server right click My Computer and click properties. Write down what the workgroup name is.
Now go to the Vista laptops and goto Control Panel, then network places, or view wireless devices on network. Hopefully your shares will appear on the laptops and you can access them.
If they appear and you canot access them then you probably need to go back to step one and alter the permissions for sharing on the XP server.
Hope this helps, www.PuterCare.com
Apr 09, 2010 | Acer Aspire 5050 Notebook
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
Laserjet CM2320fxi & Windows Server 2003
Firstly if you are to scan to a "shared folder" on server, have you configured the access rights for the shared folder? Depends on how you want it, you may want create a User "LaserJet" in AD and use this account for all scans.
You should be able to do more configuration using it's IP Address web interface.
May 27, 2009 | Computers & Internet
Windows Server2003
Hej again,
Start the Server by using Last Known Good Configuration like this:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press ENTER
You have now bypassed the last installed driver, therefore you need not do anything more.
If – you need to installed this printer on the Server (in order to share it on the network) use an older driver (PCL5), - ore install the driver on a computer on line at all time and share it here, ex. your own admin computer.
The driver I´d recommend is to be found here:
Plz, let me know if I´m right.
/Teis
Jan 04, 2009 | Computers & Internet
How to configure samba server
Hi satveergaur
Follow these instruction to configure samba server
To configure Samba using a graphical interface, use the Samba Server Configuration Tool.
The Samba Server Configuration Tool is a graphical interface for managing Samba shares, users, and basic server settings. It modifies the configuration files in the /etc/samba/ directory. Any changes to these files not made using the application are preserved.
To use this application, you must be running the X Window System, have root privileges, and have the redhat-config-samba RPM package installed. To start the Samba Server Configuration Tool from the desktop, go to the Main Menu Button (on the Panel) => System Settings => Server Settings => Samba or type the command redhat-config-samba at a shell prompt (for example, in an XTerm or a GNOME terminal).
Note
The Samba Server Configuration Tool does not display shared printers or the default stanza that allows users to view their own home directories on the Samba server.
 Configuring Server Settings
The first step in configuring a Samba server is to configure the basic settings for the server and a few security options. After starting the application, select Preferences => Server Settings from the pulldown menu. The Basic tab is displayed as shown in Figure 24-2.
 Configuring Basic Server Settings
On the Basic tab, specify which workgroup the computer should be in as well as a brief description of the computer. They correspond to the workgroup and server string options in smb.conf.
 Configuring Security Server Settings
The Security tab contains the following options:
Authentication Mode — This corresponds to the security option. Select one of the following types of authentication.
ADS — The Samba server acts as a domain member in an Active Directory Domain (ADS) realm. For this option, Kerberos must be installed and configured on the server, and Samba must become a member of the ADS realm using the net utility, which is part of the samba-client package. Refer to the net man page for details. This option does not configure Samba to be an ADS Controller.
Domain — The Samba server relies on a Windows NT Primary or Backup Domain Controller to verify the user. The server passes the username and password to the Controller and waits for it to return. Specify the NetBIOS name of the Primary or Backup Domain Controller in the Authentication Server field.
The Encrypted Passwords option must be set to Yes if this is selected.
Server — The Samba server tries to verify the username and password combination by passing them to another Samba server. If it can not, the server tries to verify using the user authentication mode. Specify the NetBIOS name of the other Samba server in the Authentication Server field.
Share — Samba users do not have to enter a username and password combination on a per Samba server basis. They are not prompted for a username and password until they try to connect to a specific shared directory from a Samba server.
User — (Default) Samba users must provide a valid username and password on a per Samba server basis. Select this option if you want the Windows Username option to work. Refer to Section 24.2.1.2 Managing Samba Users for details.
Encrypt Passwords — This option must be enabled if the clients are connecting from a Windows 98, Windows NT 4.0 with Service Pack 3, or other more recent versions of Microsoft Windows. The passwords are transfered between the server and the client in an encrypted format instead of in as a plain-text word that can be intercepted. This corresponds to the encrypted passwords option. Refer to Section 24.2.3 Encrypted Passwords for more information about encrypted Samba passwords.
Guest Account — When users or guest users log into a Samba server, they must be mapped to a valid user on the server. Select one of the existing usernames on the system to be the guest Samba account. When guests logs in to the Samba server, they have the same privileges as this user. This corresponds to the guest account option.
After clicking OK, the changes are written to the configuration file and the daemon is restart; thus, the changes take effect immediately.
The Samba Server Configuration Tool requires that an existing user account be active on the system acting as the Samba server before a Samba user can be added. The Samba user is associated with the existing user account.
To add a Samba user, select Preferences => Samba Users from the pulldown menu, and click the Add User button. On the Create New Samba User window select a Unix Username from the list of existing users on the local system.
If the user has a different username on a Windows machine and will be logging into the Samba server from the Windows machine, specify that Windows username in the Windows Username field. The Authentication Mode on the Security tab of the Server Settings preferences must be set to User for this option to work.
Also configure a Samba Password for the Samba User and confirm the Samba Password by typing it again. Even if you select to use encrypted passwords for Samba, it is recommended that the Samba passwords for all users are different from their system passwords.
To edit an existing user, select the user from the list, and click Edit User. To delete an existing Samba user, select the user, and click the Delete User button. Deleting a Samba user does not delete the associated system user account.
The users are modified immediately after clicking the OK button.
Starting and Stopping the Server
On the server that is sharing directories via Samba, the smb service must be running.
View the status of the Samba daemon with the following command: /sbin/service smb status
Start the daemon with the following command: /sbin/service smb start
Stop the daemon with the following command: /sbin/service smb stop
To start the smb service at boot time, use the command: /sbin/chkconfig --level 345 smb on
Regards,
TheAssembler
Jun 06, 2008 | Computers & Internet
Internet sharing
Hello Sir ''''''''''
>>>>>> u;r using dial up or broad band connection i do't know ok anyway connect u;r internet connection u see Taskbar right side Blink two computer's Dubble click that computers see some Option Below
######### Click Properties Go to Advanced See (internet Connection Sharing) this below -- Allow other network users to connect through this computer's internet connection. one box is thair Click that box right Mark ok byy
Apr 17, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
