Question about Kitchen Ranges
Oven running very hot and burning everything !
    Genius:
  • 1,073 Answers
Replace the thermastat or oven sensor it it does not have a thermastat with out a model can not give you a part number
Posted on Apr 17, 2008
Cloth stuck to bottom of hot oven
oven clean mode=burns everything up black dust easy to clean.
May 15, 2014 | Ovens
Oven burning food
Don't worry my wife does the same thing. Not sure if your talking about the range top or the baking potion. We'll assume the baking area. If your using cheap bakeware that could be part of the problem try using a different cake or loaf pan of heavy construction. Also you may try reducing your temp in 25 degree increments to see if your oven runs hot. Example buy 3 cheap frozen pizzas and if they say value at 400 try 375 , 350, and 325. If one of those temps gives the desired result assist accordingly and consider contracting Bosch customer service to inquire about how to fix thermostat errors.hope that helps I didn't have much to work with.
Mar 24, 2014 | Bosch Ovens
Bottom oven on Magtag Gemini burning bottoms of everything
when you set oven on bake the broil element comes on too,set the bottom oven on broil and see if the element gets hot,if not,unplug the machine or kill the power going to it,remove the element and check it with a meter to see if the element is bad,if so change out broil element if element is good you could have a broken wire or bad clock assy.there's a computer board with the clock that everything runs through,hopefully you have a bad element,if the element is coming on next thing to check is the sensor,this tells the computer how hot it is so it will turn the elements on and off,if you look behind the top panel in the back i think the paperwork is in a plastic pouch,it will tell you how to read out the sensor,i think it's 1080 ohms,or you can read out the sensor on the top oven and then check the bottom sensor and hopefully it will be a bad broil element or sensor and not the clock assy. hope this helps.
Feb 27, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Ge model jbp21gv2wh oven bottom element doesn't
Element is burn,t out, It will have to be replaced.
Nov 07, 2012 | Ovens
How does the self cleaning work?
It makes everything super hot, so that it just burns everything in there up including good stuff that makes your oven work right...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Oct 01, 2010 | Kenmore Kitchen Ranges
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
Microwave don't work
You didnt mention if the oven worked or not. Its not blowing the fuse?? Ok it could be as simple as the Diode or capacitor but dont try to touch the capacitor terminals as it holds a nice charge.. Turn on the oven for a bit with a cup of water inside and let it run for a few minutes. If you start to see smoke pull the plug right away!!!!! If you dont let the water boil(about 2 to 3 minutes thyen unplug and carefully fell around for a HOT part, But dont touch any electrical connections! If theres something drawing to much current it will get hot. Ive had bad capacitors bad and causes the transformer to get too hot. as well as bad magnatrons cause the transformer to get to hot. I would recomend that you take this unit in to be diagnoised as there are alot of voltage in this oven as I ststed before and it is dangerous for a handyperson to be fiddling with it. Good Luck
May 30, 2006 | Sunbeam SBM1000 Microwave Oven
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
