FixYa.com
Tags:
RCA CC645 VHS-C Analog Camcorder
Battery refresh problem
posted by Trelaine on Apr 17, 2008
I hadn't used my old CC645 VHS-C in years, but when I took it out of mothballs it seemed to work fine, although the battery was low. I put the battery in the charger and pressed refresh. When the light came on that it was done, I lent the camera to a friend, but I didn't test it first. He couldn't get the camera to operate and when he gave it back neither could I. I figured there was a problem with the battery, so I put it back in the charger and pressed refresh again. Now both the refresh light and the charging light are flashing at the same time. Is that normal? Do I need a new battery? I'm confused.
Comment by Trelaine, posted on Apr 17, 2008
Thanks for your prompt response. It appears to be the battery. I managed to fix the charger (the refresh button was stuck), but it looks like the battery won't hold a charge. I'm going to try refresh/charge one more time (since I'm not sure it was truely "refreshed" before it charged) and if that doesn't work, I'm off to eBay.
Cheers!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
boff1
Rank:Guru Guru
Rating: 85%, 124 votes
You will probably need a new battery as NiCd dont' last forever. However, before buying one, try out the camera on the mains adaptor. This will tell you if there is a problem with the camera.
Good luck
Rating Locked! (?) Trelaine has rated this solution as Helpful
Can you Help with these Camcorders problems?
Camcorders
problems with Power Cinema
I have a JVC GZ-MG365. When I... Answer This...
Camcorders
sony handycam dcr dvd 408won't...
I have already sent it to sony... Answer This...
Camcorders
model#GR-D71U
Can not get picture thru... Answer This...
Camcorders
disc not loading
when i insert my mini disc it... Answer This...
Camcorders
JVC digital camcorder model GZ...
Our JVC digital camcorder using... Answer This...
Repair Service
Find Camcorder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
