No sound from logitech x-230 subwoofer - Computers & Internet
  • Maartenvriel Apr 07, 2009
    I got the same problem, when I connect my boxes to my PC I get no sound at all. Though uif I plug it in at a DS/MP3-Players it does give sound.
  • Chris  Morse
    Chris Morse May 11, 2010
    Does the subwoofer use a cord connecting it to the speakers, or does it plug directly into the sound card?
    President:
  • 2,712 Answers
Try the following steps:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Posted on Apr 17, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please close the ticket with a FixYa! rating under my solution.
    I
    would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    I would be very grateful for your show of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem. (Positive
      Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem. (Positive
      Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Hello, My logitech x-230 2.1 speaker system is not producing any sound. The power light comes on but no sound at all comes from any speaker. Also, it is not the computers fault because I have used it with...
If there is an ON/OFF switch at the back of your 2.1 speakers, then switch it on. Or is the VOLUME control set at 0? Turn it up a bit.
Or, are the left & right speakers properly hooked to the subwoofer unit?
Please check.
Jul 13, 2012 | Logitech X-230 Computer Speakers
I don't hear any sound from logitech x-230, after i have installed driver into my PC
check your green cable. did you mute sound? icon next to clock, lower right corner
May 28, 2011 | Logitech X-230 Computer Speakers
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
X-230 logitech.....
For these speakers, the headphone jack is controlled by your sound card. The volume can be adjusted by using the Mixer application in your operating system.
Jul 21, 2009 | Logitech Audio Players & Recorders
Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Apr 02, 2009 | Logitech X-230 Computer Speakers
Sub very soft
Your problem could be that in your sound manager for you computer there is no subwoofer specified.
If you go into volume control, then press options and go to properties.
In the lower part there is options to tick boxes for certain things. Tick the subwoofer option then go back to volume control and CRANK IT UP :D
If this option was already enabled when you posted it could be that it does have sound but not as much as you want..... or something else with your sound card.
(Has been sometime since this was posted so...... yeah)
Soz if this bumps this... but it has no solutions and i had this prob and that fixed it for me.
GunnerElite
Apr 23, 2008 | Logitech X-230 Computer Speakers
Crap sound, subwoofer no longer working
Guys try to reinstall your audio drivers, because i had the same exact problem, so find out what sounds card you have and go on their website and download the latest sound card driver
Mar 03, 2008 | Logitech X-230 Computer Speakers
Service Manual for X-230
I used a Radio Shack D-Sub 9 Pin Connector #276-1427
Pin 1-Empty Pin 2-Purple Pin3-Yellow Pin4-Red Pin5-Shield Wire & Green
Pin6 & Pin7-Gray Pin8-Blue & Black Pin9-Brown
The pin numbers are on the face of the connector and are hard to see.
Feb 17, 2008 | Logitech X-230 Computer Speakers
X-230 Speakers Hum
bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Jan 16, 2008 | Logitech X-230 Computer Speakers
Logitech x230 speakers
Reinstall sound card drivers.
Jan 11, 2007 | Logitech X-230 Computer Speakers
Computers & Internet Logo
699 people viewed this question
David Payne
David Payne
