Question about RCA HD52W59 HDTV Projection Television
Convergence?? i'm a girl determined to repair and make my tv work again. when i turn on my hd52w59 tv there is a bowing red, blue and green line and the top of the screen. once an actual picture appears (the best way to describe it) would be a double imaging of colors (convergence being off). i have gone to the menu and the convergence option is missing. i found this site which shows a step by step how to replace a ic in a pioneer tv thats gone bad. http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm is this step by step a good guide for me to follow? is there anything different that i should or shouldn't do because i have an rca not a pioneer? where would i find the chassis number of my tv, if needed and the last question-i just want to verify the replacement part i want to get is the convergence power supply ic part number 271860?
  • 2 more comments
  • umwolvefan Apr 17, 2008
    hd52w59 picture bows in from top and bottom and extends out on the sides also colors on sides look 3d. tried convergence but no change any suggestions?
  • dopplerjones Apr 18, 2008
    here is the chassis number ITC222A, i would love any advice to my tv problem. thanks
  • dopplerjones Apr 28, 2008
    i'm a girl determined to repair and make my tv work again. when i turn on my hd52w59 tv there is a bowing red, blue and green line and the top of the screen. once an actual picture appears (the best way to describe it) would be a double imaging of colors (convergence being off). i have gone to the menu and the convergence option is missing. i found this site which shows a step by step how to replace a ic in a pioneer tv thats gone bad.http://home.earthlink.net/~oleg.filippov...
    is this step by step a good guide for me to follow? is there anything different that i should or shouldn't do because i have an rca not a pioneer? the chassis number ITC222A, i would love any advice to my tv problem. the last question, i just want to verify the replacement part i want to get is the convergence power supply ic part number 271860
  • aliall May 25, 2008
    We have a 3 year old HD52W59. It has a red shadow that bows out on the sides. The convergence set up helps a little, but we can watch it slide out of alignment within a few seconds.
    Sergeant:
    Champion:
  • 346 Answers
Did you solve the tv problem?
Posted on Nov 18, 2008
  • 149 Answers
E-mail me at networks@q.com and get me the chassis number see in the back of your tv under model number maybe chassis number
Posted on Apr 17, 2008
TV has bow on top and bottom of screen and convergence is misaligned or off with red, blue and green, which should created the laying of R, B, and G to create B/W or Color...and of course, there is no...
Thats a very easy repair that has a repair kit available called the ITC222 and ITC222A convergence option missing repair kits. Its available with instructions from www.tvrepairworld.com its listed under the RCA repair kits.
Jul 14, 2011 | RCA HD52W59 HDTV Projection Television
HI i have an RCA HD52W59 and the picture looks 3D, I can use the manual convergence but when tv is shut off and turned back on it goes back to the 3D look and the auto convergence does not work - the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
Bowed picture on Panasonic PT-53WX52F
Problem #1 - CONVERGENCE PROBLEM
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 04, 2009 | RCA HD52W59 HDTV Projection Television
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Apr 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
209 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
