Question about iRiver T10 MP3 Player
No power to t10
How do i restore power tio my iriver t10 after i tried to download the firmware and the cable was remove durin the process.
I've got the same problem and wrote to iriver. Thge only suggestion they could provide me with was to replace the battery. I tried that and it didn't work. I'm at a loss alos as to how to get my T10 to power on?
Posted on May 01, 2008
My iriver is notstarting please help me with it
check for battery problems.. Check for battery power holding with a multimeter (If u dont know get help from a person who knows measuring the power rating).
Else, if the problem is not with the battery,
try downloading and reinstalling the firmware from here.. click on the below link
http://drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-T10-Firmware-170.shtml
Thanks,
Thahir.
Feb 28, 2010 | iRiver T10 MP3 Player
I bought a used iriver T10 mp3 player and cannot find the right software to install it on my computer. Where can I find this? I have XP
The iRiver T10 player is being sold with either MTP or MSC firmware,
depending on the country it originally comes from.
For MTP firmware, you'll need software Windows Media Player 10 or 11:
this software is installed when running XP SP2 or higher.
When not connecting with WMP you'll probably have the MSC version:
iRiver Plus3 software is needed for connecting this player (see below***).
Have a look in the player's System Info for knowing what firmware version is in the device: see the manual on page 55, page 29 in the pdf file. When not having the manual, go for a download to the Tech Support site:
http://www.iriverinc.com/lounge/loungeList.asp
In the bar [select a product], choose T10 from the list and click GO on the right, to get a view of all support for the T10.
Next select in the bar [select a category] Software&Driver and click GO
on the right. Updater for MTP devices and T series MSC drivers will show up: select the matching software and driver according to the previous check of firmware version.
When needing iRiver Plus3, click Plus3 in the page top of the support page or select next link:
http://www.iriverinc.com/plus3/overview.asp
Feb 21, 2010 | iRiver T10 MP3 Player
T10 MP3 file check error
Make sure you downloaded the firmware from the official product page, if the firmware doesnt work try downloading an older version. Some firmwares have problems detecting updates.
Still, my guess is that you are not downloading from iriver site.
Jun 20, 2009 | iRiver T10 MP3 Player
My iRiver T10 2GB wont turn on. Ive changed the battery already. I was updating my iriver2 when the firmware update told me to remove my iriver for it to take effect. then when i took it out my irivers...
Press and hold the reset button for one minute and then see if it boots, after that try reinstalling the firmware if needed still.
If you ever need software for your by the way visit this website
http://www.opendrivers.com/company/27302/iriver-free-driver-download.html
Jul 03, 2008 | iRiver Audio Players & Recorders
T10 hard reset
Update the firmware - the description seems to indicate that this will resolve your issue:
http://iriverinc.com/support/ultra/t10_new.aspx
May 01, 2008 | iRiver T10 MP3 Player
Tansferring Songs
Your problem sounds different from the one I had, but you might try the solution that worked for my problem: Go to a computer that has Windows Media Player Version 10 (not version 11), use iRiver's firmware update tool to install firmware version 1.77. Then, for me at least, my T10 worked on Windows Media Player Version 11 computers.
Jan 18, 2008 | iRiver T10 MP3 Player
Windows Vista
You need to upgrade the firmware on your player. got to www.iriveramerica.com and download the firmware updater. then connect your player and run the update software.
Jun 13, 2007 | iRiver T10 MP3 Player
Iriver T10
Somehow the driver went missing. Click on "My Computer" and then click "view system information," then "hardware," then "device manager," then click on iRiver (it'll be there even without the driver) and then it will give you a yes/no option to look for driver software. Obviously, click "yes" but notice that you are also cued to put in a CD "if you have one." I still had the CD. It will search both the CD and online for a driver, but the computer found the driver software on the CD. Make sure you only put the CD in when cued to do so. If you don't have the CD, then contact iRiver about getting a driver download or having them send you a copy of the CD.
Mar 12, 2007 | iRiver T10 MP3 Player
Iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Dec 27, 2006 | iRiver T10 MP3 Player
Iriver t10
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC.
Sep 03, 2006 | iRiver T10 MP3 Player
iRiver T10 MP3 Player Logo
201 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
