Question about Mitsubishi WS-55805 55" Rear Projection Television
Suddenly, Sound But No Picture
I have sound but no picture when I ture my tv on. Look in some of the suggestions for possible solutions and quick looks does not present any issues; coolant drops, etc. Another suggestion was crt blanking, how does one verify and/or fix that?
  • 149 Answers
That is not and easy problem U need experienced tech to take a look at your TV call a local TV shop
Posted on Apr 17, 2008
No picture but sound ok
no make or model supplied
possibly a bad inverter board but need further information to proceed,,look closely into the lcd screen to see if any pic is present
Aug 27, 2014 | Televison & Video
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input).
You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through.
If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct)
Hope this helps.....
Jul 02, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
No Sound Only Picture
If a regular TV and not a plasma etc.
If set has headphone jack try that to see if sound.
If set has in the menu speakers ON or OFF look at that.
Listen right at the speakers and see if hear anything
If nothing have the speaker/s checked
May 25, 2012 | Televison & Video
My 360 turns on but no picture appears although sound is present
This is a very common . The cause clearly evident bellow.
The good news it that it can be repaired Permanently with a
proper X clamp mod , The hardware responsible (The X clamp)
Jul 13, 2009 | Microsoft Xbox 360 Console
Sony KP-53V75 picture problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 12, 2009 | Sony KP-53V75 53" Rear Projection...
Phiips 32pt5441/37 problem
Hello tvpassword,
It sounds like a power supply problem, or at least a startup issue. This might be caused by any number of problems, but I would suspect that it, the problem that is, is in the Horizontal section of your set. If this is the case I would suggest that you get this TV repaired at a qualified TV repair shop, due to the section of the TV that is involved, dangerously high voltages are present and could cause bodily harm if a mistake is made.
If you are going to attempt to do this yourself I would advise that you know electronics before attempting this, if you do not, my first statement stands.
I hope this helps,
Shuttle83
Aug 05, 2008 | Philips 32PT5441/37 32" TV
32 Toshiba TV no picture / bad pciture
Hello Suzid, It looks to me like you have a possible power supply issue (poor brightness on screen, shrinking of the picture, and initially no picture) This problem may put you in danger of electrical shock, so I would suggest that you not try to repair this set yourself. I would suggest that you take the television to a television repair shop.The power supply issue could be a low power or a high power supply problem.
Oct 03, 2007 | Televison & Video
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Mitsubishi WS-55805 55" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
