Some times my amp. in my truck will cut out. and everthing is hooked up and tight what coould this be?
    Genius:
  • 1,550 Answers
Eso puede pasar por 2 razones .
Tus bocinas estan mal o tu amplificador esta a punto de quemarse( las salidas de audio ).Checa primero las bocinas Buena suerte. ..
Posted on Apr 17, 2008
Change the fuel suction hose and filter
By using a piece of wire with a hook on one end slightly bigger than the diameter of the fuel line, fish or hook the filter & fuel line out of the tank through the filler hole. then remove the filter from the end of the fuel line. Next let the fuel line fall back into the tank then pull the fuel line out of the tank from the outside. Then to replace it with a new line. It is quite a tight fit in the tank & can be a difficult to replace. This can be made a little easier if you cut the end of hose at a sharp angle then put it in the hole. If it is too tight to slide through the hole you may need to use a pair of long nose or bent pliers to pull it from the inside,pull it out the filler hole & cut the end off square then replace the filter on the end of the hose & let it slide back into the tank. It is probable a good idea to replace the return fuel line at the same time if it hose one fitted.
Oct 13, 2014 | Garden
Cars
PROBABLY JUST A LOSE CONNECTION AT THE BATTERY TERMINAL. MAKE SURE THE TERMINALS ARE REALLY TIGHT ALSO CHECK THE TIGHTNESS OF CONNECTIONS AT THE ALTERNATOR. IT JUST SOUNDS LIKE A LOSE CONNECTION.
Sep 17, 2012 | 2003 GMC Yukon Denali
My subwoofers randomly cut out while driving. in and out in and out. but not the radio and treble. only the bass. i have a cap hooked up so power shouldnt be an issue
it is most definately a power issue your amp is cutting out due to over juicing (assuming your amp is solely hooked up to your subs and your deck is powering hi's low's mid's) as a safety precaution amp will turn off whenever your cars alternator start putting out more than 9-11 I would suggest taking a voltmeter to your car battery to see what it is at while your idling as its difficult to due while driving and adding a couple to account for the added juice from alternator running at higher speeds if it seems like it would be in the 9-11 range you may need a new alternator or battery
Mar 30, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Everthing on the amp is hooked up right but the two wires from the amp to the cd player and its in protect mode how do i get it to play
The protect light comes on sometimes when the ohms of the speakers are not ran right. if I knew what speakers you had hooked up i could help a little better.
Jan 27, 2010 | Dual Obcon OB 2000i Car Amp
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts...
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Sep 07, 2009 | Car Audio & Video
Bike wont charge?
If you haven't put a new, properly charged battery already, do so.
Good Luck and Let me know,
Obe
Aug 27, 2009 | 2001 Yamaha YZF-R6
Shuts off with preouts hooked up.
I your amp new or used and can you send me pics of how you have it in your car. I can help you with this.
Jul 07, 2009 | Car Audio & Video
Whining noise after water pump installation
If it's a 2.2 there is a special tool that holds chain while servicing the H2O pump.If you didn't have it the chain slipped & is now too tight causing the whine.You will need to take everthing apart.I woulr recommend replacing the chain & all guides(kit) Hope this helps
May 23, 2009 | 2001 Saturn L-Series
Amp cuts out
probably a loose ground or power wire in the inside of the amp
Mar 27, 2009 | Jensen XA4150 Car Audio Amplifier
Cranking
possibly a prob in the starter
Jun 03, 2008 | 1994 Chevrolet S-10
 Grubhead
Grubhead
