Question about MB Quart RAA1000 Car Audio Amplifier
Amp powers on, but stays in protect mode
Hi, I have a MBQuart RAA1000 mono amp, It powers on, but stays in protect mode. I have checked all the wiring and everything is fine. I have tried for almost 2 years to find a solution to this problem and cant seem to find a cause for this, or anyone that will fix an amp. If anyone has any idea what could cause this, please let me know. Also I feel I am a very technical person and would be comfortable fixing the amp myself if someone could point me in the right direction to get started. Thanks
  • sneeedle Apr 18, 2008
    I took several pictures of the inside of the amp, along with a closer shot of a transistor I think may be bad? I have a multimeter, but not 100% sure im doing it right. The link to view the pictures is:
    http://myweb.usf.edu/~lmcgrego/amp_pics/
  • Anonymous Jan 29, 2009
    the protect light keeps going when i hit a small bump and sometimes it just doesnt go on. Sometimes both rights are never on and the amplifier isnt even working.
  • 631 Answers
Shorted output transistors are the most common reason for amplifiers to go into protect. How much do you know about electronics/electronic components?
If you're a newbie, read THIS page.
Would it be possible to send me a set of high quality photos of the amp's internals?
Posted on Apr 17, 2008
  • Perry Babin Apr 18, 2008
    sneeedle,
    That was my post (guest). I didn't realize that I wasn't logged in.
In that group of transistors, measure the resistance from the center leg to the outer legs on each of the individual transistors. If you find any that read near 0 ohms, you need to remove them from the board and test them again. If they still read near 0 ohms, they're defective.
The SSP45N20B are difficult to find. The SSS45N20B should be a good substitute.
Posted on Apr 18, 2008
When i turn the amp on the light turn red and it goes off no green light g the amp was getting hot shotting down
when you hooked the amp up did you make sure your speakers were all in-phase positive to postive / etc.. a common issue with hi-power equiptment is grounding whatever input power supply gauge wire was used the ground has to be equalized, also if youre drawing too much on the amp (too much speaker/not enough amp ) this problem will continue till the amp cooks, check all phase, and if youre mono-bridging make sure this amp can be mono-bridgeable that would also send an amp into protection mode because its recognized as a short to positive-good luck
Jan 17, 2010 | SPL Audio Phantom DK2-1000 Car Amp
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a TN250/1 MTX class D, mono-block amp, protection light comes on and thats it. Whats the problem?
Two things, a problem with the speakers, or the amp is toast. If there is a short is the speaker, wire touching, bad voice coil, the amp will go into protect. I have also seen many, many MTX amps that go bad, and just stay in protect. the easiest way to check, is to unhook the speaker wire from the amp, then power it up, if it still goes into protect without a speaker hooked to it, you have a bad amp. Hope this helps.
Aug 17, 2009 | Car Audio & Video
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
My amp is not powering up anymore
take the amp out the trunk and connect directly to the battery, use a jumper wire for the remote from the constant power 12volt , if the amp fail to turn on it may be damage. check the fuses and look for any burnt connection.use a test light to test for power at the connection.
Aug 30, 2008 | MB Quart RAA1000 Car Audio Amplifier
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Can't find Power and Speaker Plugs For Mb Quart RAA1000 1975 mono block Car Amp.
Probably not. The best thing you can do is either contact MB directly or go to a shop that sells that amp and ask them.
Jul 09, 2008 | MB Quart RAA1000 Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
MB Quart RAA1000 Car Audio Amplifier Logo
262 people viewed this question
Top MB Quart Car Audio & Video Experts
xxxxxx xxx
Are you a MB Quart Car Audio and Video Expert? Answer questions, earn points and help others
