Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Jul 02, 2010
I'm getting a red outline on people's silhouette. Also getting a double image on printed words on my picture.
Anonymous
Level 3:
  • Toshiba Master 5,138 Answers
  • Posted on Jul 02, 2010
Anonymous
Toshiba Master
Level 3:
Answers
5138
Questions
5
Helped
1003607
Points
13534
Look on your Convergence board the one that has your STK iCs STK392-110s their should be 6 resistors all 1.8 ohms Mats Elctronics has Parts for this TV 1-800-628-1118 more then likely you have a bad resistor that controls the red.
1helpful
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
1helpful
Lots of red in pics otherwise great
If you have double image sounds like you have a convergence problem which is very common with these units.Part #STK392-110
Double words
Sounds like your red is out of convergence. You may be able to adjust the convergence in the TVs menus. It may also be possible that the TVs convergence circuitry has gone bad. In that case it would be worth to have the TV repaired, convergence board are usually fairly inexpensive.
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
HDTV 1080i studio series
hi there, its a color allignment problem, the adjusting ring is in the neck of the picture tube, the unit is on while adjusting it to the correct image. ty
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
