Question about Saeco Incanto Classic Espresso Machine
I have a saeco gran crema espresso machine that stopped making hot coffee. The pump and all the lights and buttons work. Looks like the thermostat or the heater. What do you suggest?
  • 487 Answers
Check the current over your boiler. If current is ok than your water boiler is broken and you can buy a new boiler group
Posted on Apr 25, 2008
Do you fill it up with milk?
only fill with water , use the steam wand on the side to steam milk in a caraffe or small bowl then pour coffee into milk after your done.
Oct 21, 2013 | Saeco Gran Crema Espresso Machine
No pressure in machine. i can't get any decent water stream from coffee outlet; only rare drops. steamer works fine. Can you help me?
Their are four posible reasons for above problem as follows.
First the Vibarating pump not creating pressure, usaly if here the sound it is pressing but not always. You can loose the pipe nut after the pump to see if you have any pressure after you press the coffee button. Be carefull with the water leaking.
Second the coffee solenoid valve that is on the grouphead might be stuck from dry coffee, it can be removed and cleaned with hot water and a wire brush.
Third the coffee group shower and inside round dish might also blocked from dry coffee, remove it and clean it.
Finnaly the more difficult problem might be that boiler-thermoblock is full off scale. So you must remove and descale the thermoblock boiler and the copper pipes to them.
This problem is the more difficult to be performed however if the water you have use was very hard then this is the most posible.
Good luck,
Remeber to vote for this answer.
Mar 23, 2010 | Saeco Gran Crema Espresso Machine
Exploding filter holder
The discharge solenoid is not functioning properly or the tube is dirty, try backwashing the machine.
Jan 31, 2010 | Saeco Gran Crema Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
The machine lost it's prine and now we can't seem to get it to take a prime. We've tried several times and it won't take anymore water but when we attempt to make a cup, it won't push any water through. We...
For that one you might have to take the water hose that leads into the pump fill it with water and hold it up while running the hot water cycle to prime the pump.
Nov 14, 2009 | Saeco Gran Crema 2-Cup Espresso Machine -...
Is there anywhere in Ontario that I can get a replacement portafilter for my Saeco Gran Crema esspresso machine?
Try to contact Saeco Canada to see if they can help you.
Saeco Canada Ltée
8145 Boul. St. Laurent
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
E-mail: info@saeco.ca
Visit the Web: www.saeco.ca
Jul 29, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Jun 21, 2008 | Saeco Gran Crema Espresso Machine
Saeco Gran Crema 2 cup expresso machine
You can contact saeco usa .Log on www.saecousa.com and call customer service.
Sometimes saeco have the same machine manufactured also for Starbucks.All the starbuck machine have on line manual in Pdf.
Jun 18, 2008 | Saeco Gran Crema 2-Cup Espresso Machine -...
Saeco Incanto Classic Espresso Machine Logo
108 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
